Old 01-30-2019, 06:47 AM
Stockmanreef Stockmanreef is offline
I gave up on the suggested route for the stick wires. I did not feel like cutting off the end connector and replacing. I routed through the bulkheads and through the lightning hole behind the stick. I plan to make a plexiglass insert with a bushing for the lightning hole to support the WH.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 01-30-2019, 07:56 AM
bkervaski's Avatar
There's a few places we didn't use the stock routing guidelines, the control stick area was one of them.
The biggest things (in my humble opinion):
* Be sure there are no opportunities for chafing or snagging on a moving part
* The wires are secure but loose and not taut as the airframe will move and bend
* Adequate connectors (i.e., water resistant if necessary in that area)
* Service loops
Beyond that just route the wires where it makes sense to your build keeping in mind you may need to service it later.
By the way, I believe that SteinAir makes those harnesses for Vans.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 01-30-2019, 08:31 AM
wirejock's Avatar
wirejock wirejock is offline
Default D-subs
I am using D-subs on most connections except higher amps. Those will be the heavier Molex. I plug them in and lash the two halves. Saves a bunch of weight from all the civers and screws.
https://drive.google.com/open?id=0B7...WVSNzlKM2VQRGc
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 01-30-2019, 08:41 AM
Bavafa Bavafa is offline
Originally Posted by Carl Froehlich View Post
I strongly recommend you do not try to duplicate the Van?s wiring harness - but specifically do not use those little miniature molex connectors he has for the trim servos. Just wire it the way you want - as in something that make sense to you.
Call Stein and ask what connectors he recommends.
Plus one for this recommendation and this is what I did. Very happy with my decision. You can source the little connectors that are used for the trim server digi-key as well as the pins but they are not that easy to work with. Push the pins with pin pusher for better success.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
