Old 06-02-2018, 12:10 PM
czechsix's Avatar
czechsix czechsix is offline
Default RV-14 seat belts / harnesses
Before I rivet in my seat belt attach lugs, I have a few questions for those who have already installed harnesses in their -14's:
1) The stock attachment lugs use 1/4" bolt holes and 1/8" spacing between the lugs. Other VAF threads indicate that this may not be sufficient for some harnesses (Hookers?) and I noticed the RV-7 plans spec a 3/16" gap. It also appears that the Crow harnesses use very short attach lugs that result in the harness chafing on the airframe lug, but those may have been older style and no longer a problem? Anyone have issues with either the spacing or bolt hole size with any brand of harnesses?
2) Has anyone experienced issues with the stick (at full aft) interfering with the rotary latch (aka 'cam lock') on a Crow or Hooker harness? In my RV-8 I had the latch & link style and while they were comfortable and secure, it was a challenge to get all the links in place before you could latch it (especially for passengers), so I'm leaning toward the more expensive rotary style in the -14...but I've seen a few reports of issues with the stick contacting or even releasing the rotary latch which protrudes further than other latching mechanisms.
3) Any thoughts on pull up vs. pull down lap belt adjustment in the -14? I was happy with the pull up adjustment in my RV-8, but also had more room between the seat and fuselage sides in that airplane compared to a side-by-side, so the adjustment ergonomics were different.
4) Has anyone had issues with the shoulder harness irritating your neck? Since the harness must come together to a single attach point above the baggage area, depending on the geometry of how they are connected it seems some people have had complaints in other side-by-side RVs. Do pads help, or do they just exacerbate the problem since they are wider than the harness itself?
5) 2" vs. 3" webbing?
Any other input, good or bad, on experiences with harnesses in the -14 are welcome...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 06-02-2018, 02:57 PM
MED MED is offline
I have flown in a friend?s RV-14A a number of times and have never noticed an issue with his Crow rotary latches other than the adjustment (for me) to the non-inertia shoulder belts. I bought Hooker belts with rotary latches for my RV-14A. I have not flown yet, but hope I won?t experience anything different. My belts are 1.5 inches, but the shoulder pads are 4 inches and the lap pads are 3.5 inches. Not sure what his are.
MED
140236
N435MD
Miss March 2020
Old 06-02-2018, 03:14 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Crow
I have crow 5 point harnesses with the ratchet. They work well, I would probably skip the ratchet if I did another one. They are quite a ways behind you in the -14 which makes it hard to tighten the ratchet. I can do aero easily by just pulling the straps tight. I love everything else about the crow belts. They feel good and look good.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
Old 06-02-2018, 03:54 PM
czechsix's Avatar
So no issues with installing the Crow or Hooker harnesses in the RV-14 attach lugs? No mods required?
Mark Navratil
Spring Hill, KS
Old 06-03-2018, 01:06 AM
M McGraw's Avatar
Default Crow
I don?t remember modding the -14 kit, but I did cut a bushing to reduce the crow mount by one bolt size.
Marvin McGraw, 5TN4
Flight hours: 500+
2020 Dues Paid
Old 06-03-2018, 11:58 AM
czechsix's Avatar
That makes sense, looking at Crow's website it appears they are still shipping harnesses with 1/2" attachment holes and the 14 (and probably all RVs) use 1/4" bolts to attach the belts. Would be nice if Crow would throw in some bushings with 1/2" O.D. and 1/4"I.D.
Mark Navratil
Spring Hill, KS
Old 06-03-2018, 05:25 PM
Don E Don E is offline
Default No problem with my Crows
I ordered mine thru Abby at Flightline Interiors and they fit my RV-14 perfectly. I have not flown yet, so cannot comment on any possible stick interference. Mine are 5-point restraints with the rotary latch, which is nice.
Edit/update: 25 hours into Phase I with no issues. Love the Crow restraints and rotary latch.
Old 06-03-2018, 10:27 PM
n982sx n982sx is offline
Same here.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-02-2019, 06:59 PM
Stockmanreef Stockmanreef is offline
well, I posted this in the "general" section, but I got crow seat belts and the attachment fittings on the belts are not correct. At least the belts I got. The holes in the attachment are 1/4" for the lap and shoulder, when they should be 5/16" for the bushing. Then the hole in the crotch attachment is 5/16", when it is supposed to be 1/4" (no bushing).
I assume that I have to return them to get the correct holes in the attachment fittings.
Does this make sense?
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 12-08-2019, 05:04 AM
Jetmart Jetmart is offline
any thought son this question?
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
