Old 09-04-2017, 08:09 PM
Aluminum Aluminum is offline
Originally Posted by SabreFlyr View Post
I'm a few months from needing to worry about this and haven't studied it yet but this confuses me a bit. You DON'T want the ground connected to either the pitot tube or its mount?!?
Correct, wire the ground all the way back to the bus with same size wire as the power wire.
This applies more generally: all your high-amp circuits should go into a "star" where all the return current comes back to a single bolt on the bus--your reference ground. If you return the ten amps through aircraft skin, then connect another sensitive instrument's ground to the skin halfway to where the high-amp current originates, you will see that ground voltage fluctuate from reference zero as the skin has a small but finite resistance. If the high-amp current is intermittent, your readings on the other instrument end up jumping all over the place.
Old 09-04-2017, 08:54 PM
JDA_BTR JDA_BTR is offline
The problem with the pitot heat controller is that the chassis itself is grounded, and this is the same ground as the line that normally bolts to the wing structure. This is done for a few reasons, and is part of the way the MOSFET in the system is grounded to carry the heater current and the heat sink design to the case. So I don't think that it is possible to completely return the ground current via the ground lead. Most might go that way but a very significant portion will return via the chassis mount. The controller case should not be isolated from the mount with fiber washers; it is designed to be grounded. The ground return line exists to ensure there is a good ground return separate from the chassis mounting, and because the resistance to ground via the case is sometimes a little higher because the mounting hardware isn't as reliable for electrical connections. But I haven't checked the differences because I haven't cracked the case to see. A lot of circuits like this have a ground lead on the same connection inside that bolts to the case - the screw that holds the MOSFET down.
I think that putting a larger diameter wire cuts down on impedance as well as reducing overall resistance but is probably a trivial difference for the magnetic field of the power feed.
If it wasn't for the proximity to the magnetometer it would be moot. Nuckoll's book says wire to the chassis don't worry about it and that is correct in general.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 09-05-2017, 05:54 AM
For JDA's case I would try to mount the box to a heat sink, and keep the heat sink electrically insulated from the airframe. Any decent electronics store sells very thin mica sheets, along with dielectric grease. These are electrically insulating but provide pretty good heat transfer.
Old 09-05-2017, 08:52 AM
SabreFlyr SabreFlyr is offline
I think I was a bit sleepy when I wrote my response last night. It registers with me now that connecting the ground to the mounting hardware or the tube would route ground through the airframe. I guess I must have been thinking "where is ground coming FROM?," if that makes sense. But, at the same time, I was thinking that the tube was grounded through the chassis as Dudley (JDA) says. I can see mounting with mica and dielectric grease if that provides an adequate heat sink but I'm wondering if the mounting bolts wouldn't still ground to the wing. I guess you would also use the dielectric grease in the bolt holes and use a fiber washer but then I wonder if you wouldn't end up with some grease on the bolt/nut interface.
Ray Dosh
LJ45 driver
RV-14 QB #140212
Tail feathers finished
Tail cone in progress
2020 DUES PAID
Marion, IN MZZ
Old 02-09-2019, 12:40 PM
squarebush squarebush is offline
Has anyone installed the pitot in the right wing just to remove any doubt of interference with the magnetometer? I?ve heard both sides of the coin. Some have done shielded and/or twisted pair with both good and bad results. Doesn?t look like it would make any difference as far as location on the plans or any other conflict.
Todd
RV14a
Henderson , NV
Wings done
Fuselage in progress
N617CT Reserved
Dues paid 2018 X2; 2019
Old 02-09-2019, 01:04 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I put my pitot in the right wing. When I called Van?s about it they said ?well we have just always put it in the left? no issue to put it in right. I?m not flying yet but I have only the lights and magnatrometer in the left wing tip, everything else is in the right. I?m hoping this is a simple solution to this issue. Also I ran a shielded 12 ga wire to the pitot.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 05-16-2019, 06:22 PM
Cannon Cannon is offline
What about running a single 12ga shielded wire and using the shield for the ground return? This is how lots of LED lights are wired.
1976 C-185
1947 J3C-65
RV-8 project
Old 05-16-2019, 09:05 PM
Probably can be done on some stuff but my avionics guy said with the higher amperage of the pitot the ground return needs to be the 12 or 14 gauge as well. Going to do a 2 wire shielded 12 gauge.
Todd
RV14a
Henderson , NV
Wings done
N617CT Reserved
Old 05-17-2019, 05:33 AM
JHartline JHartline is online now
Another data point from a flying 14... my installation is all Garmin with an unregulated GAP26 on a Gretz mast, magnetometer on the bracket in the left wing, Vans (SteinAir) standard wiring plus an 18 ga ground wire for the probe running all the way to the firewall (so no twisted pair). Turning the pitot heat on barely registers on the interference test. Moving the ailerons gives a higher spike oddly enough. I ran the wires exactly per the plans and, as Walt mentioned, crossed my fingers. Maybe that?s the secret but my interference test passes easily.
I have read of others having interference when using the regulated probe in a similar installation.
James Hartline
Carrollton, GA 5GA2
RV-14 - First flight 4/7/2019. Phase I complete as of 9/11/2019!!
Old 05-17-2019, 11:06 AM
mturnerb mturnerb is offline
I ran 14 gauge, twisted the wires, no shielding. Garmin regulated pitot. No interference whatsoever.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
