Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 01-21-2013, 09:24 AM
Geeman Geeman is offline
Default Co-pilot removable stick (Wiring connections)
I have an Infinity Stick grip with PTT and elevator trim on the co-pilots side. I remove it on occasion, and currently have spade connectors on the individual wires and it is a pain to remove them and stuff all the wires back in. Anyone know of a plug I could use for this. 5 wires if I remember correctly.
Kyle Gee
Purchased and sold flying RV-6
RV-7 Kit (sold to purchase C150 to train my kids)
Purchased flying RV-7
Old 01-21-2013, 10:16 AM
Bevan Bevan is offline
Default D-sub
Someone trimmed a DB9 connector and epoxied it into the stick and base to make the connection and apparently worked well. I've been considering doing it with a Dsub external of the stick. Bring the wire out of a hole near the base of the stick and just plug it into it's mate nearby.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 01-21-2013, 10:29 AM
Golf Echo's Avatar
Golf Echo Golf Echo is offline
A 6-way Deutsch DT series connector would work nicely, and is quite compact.
Graham
Empennage [in progress]
Wings [inventoried]
The plan(?): Tip-up | AeroSport IO-375 | WW 200RV | Vertical Power VP-X | Garmin G3X
VAF dues paid - Dec. 2013
Old 01-21-2013, 10:35 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
A gold plated model RC connector might work well here...
http://www.wsdeans.com/products/plugs/micro_plug.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-21-2013, 10:46 AM
bruceh's Avatar
bruceh bruceh is offline
I put a DB-9 connector inside the shaft of the control stick.
Works great! Easily removable. I wrote up what I did on my web site.
Male connector in the removable stick.
Female connector down in the control weldment.
The Tosten grip I have uses 10 wires, but 2 of them are a shared ground, so all 9 wires are used.
Bruce Hill
RV-9A N5771H flown over 800 hours!
2020 VAF donator
EAA Tech Counselor, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 01-21-2013, 11:50 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
I used a small circular 7-pin connector and a quick disconnect for the copilot stick as shown here:
I got the connectors from Mouser Electronics, check their stock to see what is current because these are pretty old.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 01-21-2013, 01:11 PM
michael_c michael_c is offline
I ordered my Infinity grips at airventure last summer and spoke with the owner to figure things out. He suggested:
http://www.gulfcoastavionics.com/pro...connector.aspx
for this purpose. I am just about to order one, it looks similar to Pat's, but with more connections so it should support everything you can have on the Infinity grip.
RV-8 fastback
Aerosport IO-375, Whirlwind 200RV
Working on FWF
2012 paid
Old 01-21-2013, 01:37 PM
Pat Hatch's Avatar
Ouch! Look at that price. Be sure and get them from Digi-key or Mouser--they'll be a lot cheaper! But this is basically what I used--just get the number of pins that you need. Thanks, Mike.
Pat Hatch
RV-7 (Sold)
Track Me
Old 01-21-2013, 02:01 PM
Default Part # ????
If you can figure out the part number from Mouser or DigiKey let me know. There are about 50,000 connectors to pick from and this is not my expertise.
Thanks.
Kyle Gee
Old 01-21-2013, 02:23 PM
az_gila's Avatar
Exclamation
Thanks.
For a two or three pin connector the Conexall Micro-Con connectors work well with a max diameter of 0.530 inches.
Easy to pick off this Mouser catalog page -
http://www.mouser.com/catalog/catalogusd/645/1504.pdf
The slightly larger (0.715 diameter) Mini-Con series on the same page work well for connectors in cables to Vans trim servos with up to 6 pins.
They are solder cup connectors so no special crimp tools needed and are weatherproof. The prices are very reasonable.
Gil Alexander
