Old 07-15-2019, 11:52 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Default Bench power voltage
A buddy of mine loaned me a bench power supply that is putting out 14.8 volts. Seems a bit high, anything to worry about using it to test items in my plane as I build? It is an American made unit that goes up to 30 amps (not ebay **** from china).
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 07-16-2019, 06:56 AM
maniago's Avatar
maniago maniago is offline
Probably not a problem, but its a bit high for my liking. Theres always a voltage pot inside, so if it were me, I'd open it up and turn it down to 14.4 if you have something with rechargable batteries, 13s if you dont. No need to push the internal regulators of your expensive gear on the bench.
BTW unless your American supply is from the 1970s, its undoubtedly assembled with chinese parts.......just like everything else.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 07-16-2019, 10:26 AM
fl-mike's Avatar
fl-mike fl-mike is offline
set it to 14.2V if you can.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 07-16-2019, 11:29 AM
Av8rRob's Avatar
Unfortunately the lowest I can set it with the little pot screw is 14.78. Any other ideas?
Rob Lasater
Paid Dec 2019
Old 07-16-2019, 11:47 AM
Use an automotive battery.
Be careful not to reverse polarity.
Charge the battery when not powering the aircraft.
Joe Gores
RV-12 Flying
Old 07-16-2019, 07:20 PM
Av8rRob's Avatar
Sounds like a simple solution. Thanks
Rob Lasater
Paid Dec 2019
Old 07-16-2019, 10:51 PM
SHIPCHIEF SHIPCHIEF is offline
Run the output thru a large diode, which will drop about a half a volt.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 07-17-2019, 04:28 AM
maniago's Avatar
Now thats an excellent idea. Something like this would probably fit your bill
https://www.amazon.com/NTE-Electroni...ct_top?ie=UTF8
Google for the datasheet....forward voltage is about .7v.......I'm sure you can find others.
Mani
N251Y (res)
Old 07-17-2019, 05:58 AM
Nova RV Nova RV is offline
Rob look into an Iota power converter, they are used in the RV (Winnebago) world to run electronics at campsites with 110 power and have very clean output for electronics. They also charge 12v batteries. I have used one for 15+ years to power my big R/C battery chargers (30+ amps) and bought another one to run my avionics in the hangar.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
