Old 04-20-2019, 07:46 AM
RogerH's Avatar
RogerH RogerH is offline
Default Oil Filter Change Question
About to do my first oil filter change on a Lycoming IO-360 and searching the Internet I'm a bit confused on whether to lubricate the filter gasket prior to installing and torquing or not.
From my checking on-line:
Lycoming documentation says do it, Tempest says no, Champion doesn't directly answer the question.
What do folks commonly do?
Thanks for any info!
Old 04-20-2019, 07:48 AM
I always dip my finger in oil (clean or dirty, doesn't matter) and apply a light film to the flat part of the seal.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-20-2019, 07:50 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Tempest has a new filter called EZSpin that doesn’t require lube like its old version did. For all others, as far as I know, a light film of DC-4 is appropriate or oil if DC-4 is not handy. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-20-2019, 08:05 AM
Sam Buchanan's Avatar
been here awhile
Default Don't over-tighten
Follow the directions on the new filter for proper torque....it is easy to over-tighten which can make the filter very difficult to remove.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 04-20-2019, 08:18 AM
RogerH's Avatar
Default Now it makes sense!
OK, now I get it. I didn't catch that the current filter is a Tempest "EZ-Spin" which says on the exterior to not use lubrication.
I'm going with a new Champion so I'll follow the Lycoming procedure.
I did pick up a torque wrench from ACS but seems like most postings I've seen indicate a 3/4 turn from initial seating ends up about right.
Thanks for the info!
Old 04-20-2019, 08:26 AM
I have always used 3/4 turn, never had an issue.
Are you aware of the screen in the sump?
Old 04-21-2019, 07:28 AM
RogerH's Avatar
Nope, haven't got any info on that, is it something readily accessible, how often does need cleaning?
Old 04-21-2019, 07:47 AM
RogerH's Avatar
Thanks for the heads up! I did find the thread on here that explains the situation...not quite clear on what size crush washer the IO-360 will need but for sure will get the screen checked & cleaned on the next oil change.
Old 04-21-2019, 08:04 AM
AlexPeterson's Avatar
AlexPeterson AlexPeterson is offline
Easy way to properly torque is to use a 1" box wrench being pulled at 90 degree angle with a fish scale. The moment arm is a bit under a foot, so I pull until I see about 18 lbs. I haven't noted how much the rotation is from first contact.
Alex Peterson
RV6A N66AP 1700+ hours
Maple Grove, MN
Old 04-21-2019, 08:17 AM
flyinga flyinga is offline
You'll need a 1" crush washer (AN900-16). I clean the screen with every oil change. If you have a tail dragger be prepared to catch about a pint of oil when you remove the screen.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
