Old 08-20-2018, 08:27 AM
Mark Dickens's Avatar
Default Need APRS Guru Help
I have a Byonics RTG-FA permanently installed. It gets GPS from the Skyview over a 9600 baud serial connection and I get a steady green LED almost immediately on power up (after the Skyview is powered up of course), so I assume the GPS coordinates are legit. I'm transmitting the NMEA Basic information to the RTG. I configured the unit per Sam's sticky post with the exception of using 9600 baud. I have smart beaconing turned on. Mic-e is also turned on. The antenna is a Laird Phantom Elite ETRA 1440 mounted onto one of my inspection plates under the right wing connected via a RG-174 coax terminated with a NMO connection.
So, out of all the times I had it on this weekend, and this includes a Pilots N Paws mission flying as high as 9000 ft (on the return leg without the dogs of course), I got nothing recorded on aprs.fi. I did get one beacon on Saturday, but that's it.
I have not yet tested the coax and antenna, and I will. I have an antenna analyzer, but I was wondering if there was anything in the configuration I should check or if there was any way to see if it was transmitting with bad data.
Yes, I'm a ham (K0MDD), but I have the tracker set up with N678MT as the call sign.
Any ideas other than just checking the antenna and coax?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-20-2018, 10:10 AM
rleffler's Avatar
rleffler rleffler is offline
I've had similar symptoms twice. One was a physical wiring issue and the other one was a dead gps puck.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-20-2018, 10:53 AM
gnuse's Avatar
gnuse gnuse is offline
Have you checked with Allen -- Byonics? I have always had great help from him.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 08-20-2018, 12:17 PM
Assuming the ?green LED? refers to the tracker, I?d start right where you already suspected - by test the antenna and output of the tracker.
Old 08-20-2018, 01:13 PM
The tracker is new so hopefully it's putting out rated power. I'll check the antenna and cable
www.marksrv8.com
Old 08-20-2018, 01:30 PM
Bevan Bevan is offline
Check the power input cord and secure it in such a way that the plug is held in tight. It may vibrate out. Ask me how I know.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-20-2018, 02:28 PM
pa38112 pa38112 is offline
A couple of things I would check. I would open the cover on your Byonics and re-install everything, but leave the wing access panel slightly open so you can see the LED's. Power up and see if it stays green, or does it fault? For some reason mine would fault when installed in the wing, but was happy if I pulled it out into the wing-tip. It did not like being confines in a metal area.
Also, do you have a coil or two of coax between the Byonics and the antenna?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 08-20-2018, 02:32 PM
Bevan
I know it's getting power since the VPX tells me it's drawing power, so that's not the issue. I'm thinking bad coax but it will be two days before I get out there and test it with my antenna analyzer. If it's not that, it's the antenna, but I doubt that since it's essentially new.
www.marksrv8.com
Old 08-20-2018, 02:34 PM
The transmitter is mounted behind the instrument panel, and I'm getting a constant green LED. I do not have a coil of coax between the transmitter and the antenna. Should I?
www.marksrv8.com
