Mobile Tool Stands
Torch76
Member
I've seen people make reference you a wheeled stand where they put a bench grinder, drill press, bandsaw, vice, etc. I am looking to build one.
I'll take any and all input and picture of yours.
Much appreciated!
Bench
No wheels on mine. It's just a 4'x3' version of an EAA bench. Basically utilizing all the leftover plywood plus enough 2x4s to assemble it. I do recommend giving serious thought to your personal work flow and which get the most use. Everyone works different.
https://photos.app.goo.gl/uUayrzfRvb2TBYx98
My list
Drill press, grinder, band saw, vice, disk/belt.
I'll upload a more recent photo of what I built as well as some dimensions as soon as I get home.
Basically it started as storage for my table saw but turned into a pretty nice tool stand. I basically have 4 tools mounted to the top. Band Saw, Drill Press, bench grinder, and belt sander. It's not perfect as I sometimes have to shift the drill press slightly, but overall it works great and it's easy to move between tools when making parts (band saw -> belt sander -> Bench Grinder w/ Scotchbright wheel).
Below is what it looked like before the drill press and bench grinder. DRDT-2 doesn't work on the cart that well.
I've made several wheeled stands. No pix, but I have 2 in the shop right now.
One of them is has a top about 24" square and has both a bench top drill press and a belt sander on it. It's on harbor freight castors so I can leave it in a corner and just spin it around for whichever tool I need.
The other one is just the cabinet portion of an old wal-mart bbq grill that was junk. I unscrewed the grill portion and junked it, screwed on a top made from a piece of plywood and put my grinder/buffer on it. that one has the added benefit of having a nice storage area with doors where the gas canister used to go.
Ok, so size of the cart is really up to you. I sized it to fit the portable table saw that is stored in the bottom. I planned to build drawers or add a shelf above the saw, but never got there.
Overall dimensions. 26"x26"x34". Used most of a sheet of 3/4" plywood and mounted casters on the bottom. Electrical extension cord, some Zip-ties and a few bolts to hold down the band-saw and bench grinder and it's all good. Easier than building the EAA table.
Best part for me, I can tuck it against a wall and out of the way when not in use. In a perfect world, I would love for these to be bench mounted against a wall, but just don't have the space at the moment. Maybe when I get a T-hangar that may be an option.
*Edit yes, I know it doesn't look perfectly square, but it hasn't fallen apart yet!
Tony Bingelis
Do any of the other oldtimers feel the spirit of Tony Bingelis floating through this thread? One of his books shows his version of this idea over 30 years ago.
I built two movable tool tables based on Mr. Bingelis’s design about 17 years ago. One part of his table that I don’t see in any of these photos is a 2x4 mast extending up to about 6 feet above floor level. With a power strip on the mast and 110volt outlets in the ceiling, a heavy duty extension cord can bring power to the mast without the clutter of a cord between the wall and the table. This also allows the table to be moved or rotated easily.
One of my tables has a vise, a band saw and a chopsaw, while the other has a belt sander, a drill press and a bench grinder.
This is a great way to conserve precious floor space in a typical RV shop.
This one is made with 2X4s, some 3/8" plywood from the scrap pile, and some black laminate I had left over from another project. The joinery is pocket-hole screws using the Kreg pocket hole jig. Some good locking heavy duty wheels make it easily moveable:
Not sure who had the original idea, but I stumbled across it in one of the Bingelis sportplane building books (which if you don't have, you should). I have a similar setup to the ones posted here, but I incorporated a 2x4 "post" in the middle of the table. At the top of the post I mounted a power strip. My shop is / will be in a garage (still unpacking 2 months later), where there's an outlet in the ceiling feeding the garage door opener. Spare outlet from that feeds an extension cord that supplies the power strip at the top of the tool stand post. So, while moving the stand around, cord is "up", not on the floor annoying you.
I made one too..
My version.... but it doesn't hold any power tools. I have all of them mounted to a piece of wood and can clamp them to any surface table I like or need. Takes a bit of effort but gets the job done if you have limited space.
download
download
download
