Old 11-04-2019, 09:07 AM
sailvi767 sailvi767 is offline
When I owned my six it was set by the builder at 1800lbs. I was fine with it because the six probably has more actual flight hours than any other Vans model and as far as I can tell never experienced a inflight breakup. The same can?t be said of some other Vans models with fewer flight hours.
Old 11-04-2019, 09:13 AM
I have no horse in this race, having built a Glasair Sportsman rather than an RV.
With that having been said, I've seen what Glasair did to boost gross weight in the Sportsman from 2350 to 2500. Just the increase in size of the wing strut and strut attachments and bolts is enough to pop one's eyes WIDE open. Increases in tubing diameter and thickness in the steel "roll cage" also give an observer the impression that design gross weight is indeed a maximum number.
There ain't no way in heck my airplane is flying over 2350 unless it's in a serious life-saving emergency mode of operations. And even then it would be done with extreme caution and with great respect for airspeeds and the need to adjust them to very conservative levels.
Again, I don't have a horse in this race, but provide the Sportsman as an example where one can see how much beefing up of structure had to be done to add 150lbs of gross weight capacity. It's not insignificant, not in the least.
Old 11-08-2019, 02:38 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
I do stress analysis and certification of aircraft structure. Not going to argue MGW (max gross wt.) but a few comments.
Gust load condition will produce higher G loads when operating an aircraft at *lighter weight*, for a given speed. The lighter AC weight the lower maneuvering speed (Va or Vo). Refresher, big fan of Rod Machado.
https://youtu.be/BAy4w3SYCTo
1800 lbs RV-6 is totally arbatray set by builder based on operational needs. Experimental airplane, end of story. [Question: Does every builder go through and evaluate all the performance and speed limits maticuliously during phase 1 at higher 1800 lbs gross weight?]
We don't know how Van designed/sized structure, set original MGW, determined limiting critical load cases and structure. Van is a degreed Engineer and sure he did "classical stress analysis" to size the structure (and was conservative). Van I also assume used certified aircraft 1.5 factor of safety [limit/design load x 1.5 = ultimate load] to size his structure.
I have not reviewed Van's stress analysis. From +40 years and thousands of RV's flown safely we can assume Van did a good job (including the few in-flight breakups which had causes other than deficits in design). With that said you can break an RV if you do something stupid.
RV-6 has an aerobatic [1375 lb] MGW at +6G. Normal category planes are 3.8G. You can fly your RV-6 at 1800 lbs or [30%] higher than published aerobatic Wt. and wings will not fold up, if you fly your RV like a normal category plane, straight & level. Regardless increase of MGW from 1600 to 1800 a 1.125 factor increases stress and reduces your margins in the air or on ground. [edit]
Exceeding MGW on GA planes is often an issue with low performance GA planes because they will have marginal performance. RV's have an abundance of performance. However at 1800 lb RV on hot day, high DA is not going to perform like a light RV. Also as mentioned aft CG makes it unstable as well.
There have been RV LOC (loss of control, stall) accidents where over gross Wt. and CG was a factor. In fact LOC is one of the biggest causes of accidents. Higher gross and stall speed is not helping.
Bottom line higher gross weight lowers performance and increases stress on the aircraft. Is it unsafe or critical?That's up to the builder and PIC? It's an experimental aircraft. Obviously at operations at 1800 lbs max gross weight one should limit the G loading on the aircraft and land smooth, while avoiding max performance T/O and Ldgs.
Last is Joy, I have flown very light RV6 with a wood prop and they was delight. I've flown really heavy RV6's and they lose a lot of the feel and enjoyment of a light RV6.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 11-08-2019, 03:10 PM
lr172 lr172 is online now
Originally Posted by gmcjetpilot View Post
RV-6 has a 1600 lb MGW at +6G. Normal category planes are 3.8G.
RV-6 has a lower MGW for 6G / aerobatics, as well as a shorter aft CG. Maybe 1350 or 1375. I don't remember, as I don't fly aerobatics.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 11-08-2019, 03:22 PM
RV8JD's Avatar
RV8JD RV8JD is offline
... RV-6 has a 1600 lb MGW at +6G. ...
This is incorrect. The RV-6/6A is stressed for +6g (Aerobatic Category limit) at 1375 pounds.
Note that the Max Gross Weight is 1600 pounds for the RV-6, and 1650 pounds for the RV-6A.
Refs:
RV-6: https://www.vansaircraft.com/wp-cont...9/01/RV6wb.pdf
RV-6A: https://www.vansaircraft.com/wp-cont.../01/RV6Awb.pdf
Carl N.
Arlington, WA (KAWO)
RV-8, 750 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 11-08-2019, 03:30 PM
Originally Posted by lr172 View Post
RV-6 has a lower MGW for 6G / aerobatics, as well as a shorter aft CG. Maybe 1350 or 1375. I don't remember, as I don't fly aerobatics. Larry
Thanks, fair enough... forgot about lower aerobatic weight. So 1375 to 1800 is about 30%. So at 1800 lbs you would be around 3.8G limit of utility category plane.
To be clear I'm not condoning or recommending Flying at higher than 1600 lbs ever.
George
Raleigh, NC Area
2020 Dues Paid
Old 11-10-2019, 09:48 AM
Snowflake's Avatar
Snowflake Snowflake is online now
This only applies if the extra 200lb you're adding to the airframe is distributed evenly throughout the airframe. If you could "spread" 200lb of paint on the airplane, then yes, operating it at 1800lb and restricted to Normal category only would be no more dangerous than operating at 1600lb and restricting to Utility category.
When you take the extra 200lb and load it in *one place* in the airplane, say by carrying two "bubba" passengers (270lb) instead of two ICAO standard passengers (170lb), you "point load" the airframe, and the structure near that extra load isn't just carrying 1800/1600 or about 1.15x the load it saw before, it's now seeing 270/170 or about 1.6x the load it saw before.
As someone else said before: "It's not just the wing loading."
Rob Prior
Old 05-20-2020, 12:10 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
Location: Zuerich W, Switzerland, Europe, Earth, Milky Way, known Universe...
Default 50lbs for the -6
here?s an official 50lbs increase, thanks Vans
http://www.vansairforce.com/communit...=1#post1431892
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 05-20-2020, 04:07 AM
wilddog wilddog is offline
Originally Posted by Gyrodoug View Post
My naive question is: As the 2nd owner of the RV6A, can we adjust the builders gross weight of 1650lbs up to 1800 lbs? One response above was, "Phase 1 Flight test". Is that sound accurate to the rest of you?
When the Sport Pilot rules came out some pilots wanted to lower the gross wt of their planes to meet the rules. FAA would not allow it. Don’t know about increasing the wt?
Old 05-20-2020, 11:35 AM
UrbanM UrbanM is offline
This is addressed on the EAA Website. For whatever reason the FAA treats weight increase for LSA as a one way street. Once an airplane has been certified above 1320 LBS it no longer qualifies for LSA (edit; even if the Gross Weight is recertified below 1320)
Kirk
(Disclaimer, this was as of 2017. If anyone has more current information please post)
