Old 10-27-2018, 06:40 AM
pilot2512 pilot2512 is offline
Default wing tip reinforcement strip
I finally got my first wingtip all lined up and drilled for nut plates. According to the plans there is a reinforcement strip needed if you use pop rivets but not needed for nut plates. Some builder sites I've seen still use the reinforcement strip with the nut plates. Anybody have an issues with the nut plates and no reinforcement strip.
thanks!
Jay
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 10-27-2018, 06:54 AM
Mel's Avatar
Mel Mel is online now
The reinforcement is needed for pop rivets because the small round "shop head" can pull through the fiberglass quite easily. The nut-plate has a much larger footprint. So the reinforcement is not needed.
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School RV-12 Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-27-2018, 07:19 AM
mike newall's Avatar
If you are on batwing tips, you may also want to consider some spanwise reinforcing using 1" square blue foam glassed in with deck cloth.
When you come to pushing and pulling your aeroplane when finished, it stops the tips deforming.
Plenty of refs on the forum
Donated in 2019
