Old 07-08-2018, 03:56 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default ICOM A220 Receive Dies
After multiple problems with my A210, and for simplicity in spite of misgivings, I swapped it for an A220. After less than a year that too is now playing up.
After a flight of an hour or so everything goes quiet without even background chatter on the comm from distant stations on the primary or dual watch frequencies. On switching the radio on then off the it receives clearly. I'm told that it still transmits.
Has anyone else experienced this problem?
This is completely different from the A210 problems that included random frequency changes and other gremlins.
Jim Sharkey
RV6
Jim Sharkey
RV6 YO360-A1A
Flying Since 2009
Old 07-08-2018, 05:52 PM
N804RV's Avatar
N804RV N804RV is offline
The 210 and 220 both are plagued with face-plate to tranciever to tray connection problems. They really made that box much more complicated than it should have been.
I'd re-rack it and be careful to insure the ribbon cable for the faceplate is properly connected and stowed.
If you're not familiar, you can probably find someone nearby who is.
If that doesn't fix it, pester the iComm customer support folks. I've heard that several people have gotten theirs looked at and ribbon cables replaced for a nominal fee.
.....And, Happy Birthday!
Ken W.
Mount Vernon, WA
2019 VAF Supporter
Old 07-09-2018, 07:50 AM
rvator51's Avatar
rvator51 rvator51 is offline
Exclamation
Jim Sharkey
RV6
Hi Jim,
I had this exact problem in my A-210. I sent it in twice before it was fixed.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 07-09-2018, 11:33 AM
DennisRhodes DennisRhodes is online now
I have a spare ribbon cable for the 210 in my Hgr ,if you need it . It is possible to rack or unrack the 210 and or 220 without removing the ribbon cable connection and that's what i would recommend. Use blue tape and allow the face to be supported by the tape and work with care. This actually came from ICOM tech support. The ribbon cable and its connection is probably the reason for inoperability and certainly a weak link in that radio. I understand that the 220 has a different connection cable but may be just as troublesome.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 09-07-2019, 04:09 PM
mattwood mattwood is offline
I fly my buddy's plane (RV-7A) and it had this exact behavior yesterday on a A220 that he just installed a couple months back. Radio went quiet, although ATC later told me they could hear me while I was not hearing them. Turning off and back on restored reception.
Is there an actual fix for this problem or is it a bad unit?
Jim Sharkey
RV6
Old 09-07-2019, 08:35 PM
A2Jake's Avatar
A2Jake A2Jake is offline
Default Unreliable
My A210 just did this 10 miles from Rippon this year, did not think I was going to get in. Finally off and back on restored operation.
Never know WHEN its going to happen and seems to be Very common.
79 hours total time.
Very disappointed because we really like the A210
Any $$$ spent here will be to REPLACE with a different brand.
RV-8 Project Rebuild ( flying 4-2-2019 )
RV-8 Fastback New build in progress
Aeronca L16 Champ
Cessna 195
Old 11-26-2019, 11:42 AM
jsharkey's Avatar
Default ....any more luck finding a solution?
Any luck in finding a solution?
Jim Sharkey
RV6 YO360-A1A
Flying Since 2009
Old 11-26-2019, 03:41 PM
snopercod's Avatar
I beefed up the ribbon cable connection to the front panel with a piece of Teflon anti-chafe tape. Obviously, you have to remove the "lid" in order to do this. Then, after reinstalling the "lid", you have to gently remove the faceplate in order to screw the unit into the rack. (This is really a crappy design, ICOM) IMHO, the problem is that when you reinstall the front panel, the ribbon cable wants to bunch up inside the box. I think this may loosen the connection to the front panel. The Teflon tape may help support the ribbon cable connector. All I can say is that my A-210 has been working for a year now after I had to send it in for repair. Knock on wood...
(2020 dues paid)
Old 11-26-2019, 04:46 PM
jsharkey's Avatar
Thanks for that - however one thing they did fix on the A220 was to eliminate the ribbon cable. The dropping of receive almost seems like a software glitch or an accidental "time-out". You can set your watch by it!
Jim Sharkey
RV6 YO360-A1A
Flying Since 2009
