Old 01-17-2020, 06:02 PM
BlndRvtr BlndRvtr is offline
Originally Posted by N941WR View Post
I covered the top of my glair shield with Velcro loop fabric. (Feels and looks like a low nap flat black velvet cloth.)
Where do you get a sheet of Velcro loop fabric? I've only ever seen it in strips.
George
Old 01-17-2020, 06:11 PM
snopercod's Avatar
snopercod snopercod is online now
I moved my Stratus 2 from the glareshield to the baggage compartment due to HEAT. The sun would shine on it and it would shut down from overtemp.
(2020 dues paid)
Old 01-17-2020, 06:49 PM
Northernliving Northernliving is offline
Originally Posted by Snap-roll View Post
Question for the flying part of this section, would ?smaller? things mounted on the glare shield bother you? The reason for the question is is that I can?t find a good place for a GLD-50 other than on the glare shild and I ?m not that far in the build to be able to judge whether this will drive me nuts in the future or not
/Johan
I have the Dynon 2020 GPS receiver mounted on my glare shield in a purchased -8, and there are times when there is a very annoying reflection. I would avoid putting anything there if at all possible.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 01-17-2020, 09:31 PM
RV8JD's Avatar
RV8JD RV8JD is offline
The Dynon SV-GPS-2020 GPS Receiver/Antenna is white, and anything light-colored on the glareshield will cast an annoying reflection on the windscreen. As I mentioned in Post #14, since the GDL 50 is a dark color, I have found that it doesn't cast reflections on the windscreen of my RV-8.
Put a piece of dull black-colored cloth over the Dynon SV-GPS-2020 GPS Receiver/Antenna and it won't reflect on the windscreen.
Carl N.
Arlington, WA (KAWO)
RV-8, 785 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 01-18-2020, 03:33 AM
Snap-roll Snap-roll is offline
I was thinking of placing the SV-GPS Receiver antenna inside the canopy beside the rear canopy rail on top of the turtle deck, any disadvantages with that?
Johan Sverkerson
RV 8
Hangar/work-shop done
Wings & empennage done
O 360 A4A picked up
Working on the fuselage
Engine rebuilt, add Fly?Efii 32
Installing Sky-View
Old 01-18-2020, 07:54 AM
Electrogunner Electrogunner is offline
George
Just google Velcro fabric. I had bought mine from some online fabric store. Works great for a glareshield cover.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 01-18-2020, 08:28 AM
I'll try to cover. Thanks for the suggestions.
Brian J.
Boston, MA
Old 01-18-2020, 08:31 AM
I like this location option for the GPS. The only possible concern/objection would be the relatively long wire run to the EFIS.
Brian J.
Boston, MA
Old 01-18-2020, 01:11 PM
George
Hey George,
I covered my glare shield with inexpensive black carpet, acrylic stuff, purchased from Pep Boys. Glued it down with 3M spray adhesive. Its "loop" function is even better than Velcro itself; just put the Velcro hook tape on GPS pucks, etc. and they really stay put!
Doug
RV-9A "slider"
Flew to Osh in 2017, 2018 & 2019!
Tail number N427DK
Donation made for 2020
Old 01-18-2020, 04:19 PM
RV8JD's Avatar
No disadvantages; it's a great location. My previous RV-8 has a Garmin GPS antenna located there and it worked great. Obviously, the reflection on the canopy wasn't a problem back there. Here is a pic:
My current RV-8 has the Dynon SV-GPS-2020 GPS Receiver/Antenna under the engine cowl, on a bracket attached to the firewall. That has worked fine as well. This location requires that the cowl is not painted with metallic paint. Here is a pic:
Hope that helps.
Carl N.
(Pic 1),(Pic 2)
(Pic)
