Old 01-13-2020, 02:00 PM
bob woods bob woods is offline
Default Sniffle valve
I bought mine from airflow performance. They call it a manifold drain. $ 25.00
Old 01-13-2020, 02:29 PM
jcarne's Avatar
jcarne jcarne is offline
Oh I see, hmmm.
Can someone confirm whether it is just a simple brass fitting with a hole in it? If that is the case there is no way I'm going to give Lycoming 115 bucks for one. The one from Airflow Performance just looks like a simple AN flare to NPT fitting.
The Lycoming one found here looks like it has a check valve function to it too.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 01-13-2020, 02:46 PM
SmilingJack's Avatar
SmilingJack SmilingJack is offline
I bought a piper sniffle valve that has a 90 right Angle drain.
I can?t find the p/n at the moment.
John Mastro
RV-8
wilddog wilddog is offline
The one that came with my Titan is a check valve.
Old 01-13-2020, 03:04 PM
DanH's Avatar
DanH DanH is offline
It is not. It's a check valve. It seals at low manifold pressure, but could just as well be an open fitting at WOT, given a good ram inlet.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-13-2020, 03:19 PM
flyinga flyinga is offline
Dan,
To answer your question: yes. Constant flow with no purge valve.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 01-13-2020, 07:46 PM
jcarne's Avatar
Thanks guys, you just saved me 100 bucks. After some research I see the one that Airflow Performance sells is indeed a check valve, will be ordering soon.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Old 01-14-2020, 05:25 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Jeeeze! Where were you last week when I ordered a sniffle valve from Vans for $120.
I have been running without a sniffle valve ($120) or manifold drain ($25) for 14 years and over 2200 hours with no problems. I have an Airflow Performance fuel injection with a purge valve. I just installed a sniffle valve because it was noted as "missing" by the well-respected A&P who just did the pre-buy inspection for the person who is buying my RV-8.
I'm not making any judgement about the wisdom of having a sniffle valve, just relaying my experience. When I removed the sump plug to install the valve there was nothing draining from the hole. I am curious to know why the inlet to the sniffle valve is about 1/16 inch diameter and the outflow port is 1/4 inch in diameter! Seems like the slightest bit of crud would render it more useless than it already seems to be.
Sniffle Inlet
Sniffle Outlet
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2020 Donor
Old 01-14-2020, 08:23 AM
DanH's Avatar
Originally Posted by flyinga View Post
Dan,
Then it is common to see a bit of fuel in the air plenum, and from the sniffle.
The engine driven pump creates line pressure by pushing a diaphragm with a big spring. The engine's pump cam (via the pump pushrod and pump lever) compress the spring, then rotates out of the way, leaving the spring free to push the diaphragm.
Now shut down the engine using the mixture control. If the engine stops with the pushrod on the pump cam's base circle, the pump spring is free to push, and 25~30 psi remains applied to the servo inlet. The only thing preventing flow is the mixture disc valve....which has a leak rate. The rate is small, but it's there; it is not a zero flow valve. The leak sends fuel to the divider, onward to the nozzles, into the manifolds. Some of it runs down to the sump plenum. For the most part, the leak rate is offset by evaporation rate, and the difference is minimal.
The disc valve is common to the Bendix RSA and its variations, like the current Avstar controller, and late model Airflow Performance FM-150. Those of us using a "classic" Airflow Performance controller like the FM-200 have a drum type mixture valve. It has a much higher leak rate (1 to 3 lbs per hour) and would rapidly dump fuel into the manifolds in the above scenario. So, AFP units with drum valves also get a purge valve. When opened, the purge valve re-routes fuel from the control, before it reaches the divider, and sends it back to a tank. In consequence, purge valve users see less fuel in the manifolds after shutdown. It's limited to the very small amount which may boil out of the divider and spider lines. That happens with both mixture valve types, purge or no purge.
Anyway, the much reduced fuel dump is why purge valve users see less need for a sniffle.
BTW, a purge valve can be installed with any fuel control. The reason for its existence is per the above, but the serendipitous feature most loved is the ability to flow a large quantity of cool fuel through the entire system prior to cranking.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-14-2020, 09:55 AM
jcarne's Avatar
I hear ya, I have delayed buying that bad boy for a bit now as it just seemed way overpriced to me; like certified market overpriced.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
