Old 01-07-2020, 07:23 AM
FlyingBanker's Avatar
FlyingBanker FlyingBanker is offline
Default Lycoming Engine TBO
I bought my 2001 RV-6A a year ago with 930hrs on the airframe and engine. I did that with the understanding that the TBO for the O-360-A1A engine was 2,000 hrs. This week, I was prompted by an ad I saw to go look at the Lycoming site and specifically at the Service Instructions for TBO. I was surprised to find that there is also a 12-year recommendation regardless of time. At least, that's how I am reading it. Is this accurate? If so, my plane already has 18+ years of service. Last condition inspection was done by Vic Syracuse and all compressions were good, no metal found in oil or filter. Last oil analysis was good. Is this something I need to address in the near future as opposed to what I thought was still several years off?
Jim Bedsole
N62MG - RV-6A "Promises" - bought flying
Dues Paid
Old 01-07-2020, 08:18 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Yes and no...
Mine is 25 yrs and 1300TT.......running well.
Just be aware of the facts and maintain accordingly.
I pretty much think the 12 yr recommendation is for soft parts getting hard.
So change them when you get a chance...
example: oil drain back tubes from valve covers
intake tube connectors and clamps
intake tube gaskets at the head.
valve cover gaskets
nose seals, if they start leaking.
Mags and ignition wires as they wearout.
Fuel lines every 5 yrs unless they are the permenant ones.
You get the picture....
ohh and fly as often as you can....the engines love to run.
The above is my opinion, others can chime in too.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-07-2020, 09:32 AM
Default Also...
Also, realize that TBO time is a recommendation and not a limitation...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 01-07-2020, 10:09 AM
Jpm757 Jpm757 is offline
The other side of the coin is that Lycoming has approved TBO extensions of 200 hrs. on many engines provided they are operated 40 hrs/ mo. or more. Bottom line as we all know, these engines need to be flown, and frequently. The 12 year recommended overhaul period is a CYA for Lycoming. I would not be concerned with your engine if it has been flown on a regular basis. Any extended period of inactivity may be a cause for concern. As Bob mentioned, it is important to replace hoses, seals, and gaskets as necessary. An oil analysis program can also provide a heads up to any potential problem. Exercise prudent maintenance practices and enjoy your RV!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-07-2020, 11:41 AM
BlndRvtr BlndRvtr is offline
Written by lawyers for lawyers. Of no concern with proper preventative maintenance.
George
Old 01-07-2020, 05:30 PM
grubbat's Avatar
grubbat grubbat is offline
Default time......
I?ve got 3000hr SMOH on a pair of Lycoming IO540?s with 20,000hr total time. Good oil pressure, compression, and good oil analysis. The risk is that there will be less reusable parts at overhaul. However, I may be 80yrs old then and it will be somebody?s else?s monkey.....
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 01-07-2020, 06:29 PM
Default Keep flying
The more you fly Jim the less time you waste digging. The best rust prevention program is a daily exercise
Old 01-07-2020, 07:24 PM
calpilot calpilot is offline
Default TBO
TBO is mandatory for commercial operators. EAB is on condition. Hoses are at life expectancy at 12 years, Accessories usually are also getting tired at that age. Soooo, if you have a high calendar engine, perhaps invest $20 for oil analysis, do a " wiggle" test on guides, and be sure to inspect suction screen. I ran a Lycoming 0-360 to 3700 hours, looked great inside, but ran regularly and in a dry environment.
Old 01-07-2020, 07:32 PM
cajunwings cajunwings is offline
Default TBO
Good advice posted. Change all the rubber parts and check the valve guides. Every few years I like to get into the forward end of the crank to clean out the sludge and check for corrosion.
Don Broussard A&P-IA
RV9 Rebuild in Progress
57 Pacer
Old 01-13-2020, 08:24 PM
NewbRVator NewbRVator is offline
57 Pacer
Hi Don can you elaborate on the forward end of the crank inspection?
I just replaced accessories, hoses, gaskets, etc and the 0-360 A1A I run is humming with good compressions. Good compressions, borescope, valves look good, guides etc.
But I'd like to keep going and going.....Thanks!!!!
20 dues paid member since 2018
RV6A
