Go Back   VAF Forums > Main > Safety
Old 01-13-2020, 03:54 PM
sblack sblack is offline
Originally Posted by Hwood View Post
Anybody actually REALLY HAVE to use a chute to get out of an RV?
You can egress without one, but I would not recommend it
Scott Black
Old school simple VFR RV 4, O-320, wood prop, MGL iEfis Lite
VAF dues 2020
Instagram @sblack2154
Old 01-13-2020, 04:01 PM
I'd suggest avoiding a used helmet. Damage to the composite is hard to identify without removing the paint and internal things.
Old 01-13-2020, 04:42 PM
RV8JD's Avatar
RV8JD RV8JD is offline
RV-8. Unfortunately, the pilot did not have a chute.
https://aviation-safety.net/wikibase/38485
"A witness reported observing the aircraft at low altitude over gently rolling terrain trailing black smoke during which the pilot was observed to exit the aircraft.
Probable Cause: Fatigue of the number two connecting rod end resulting in a fracture at the rod end and release from the crankshaft, an ensuing in-flight fuel fed fire, followed by the pilot's abandoning the aircraft in flight. A contributing factor was pressure on the pilot induced by the conditions/events (in-flight fire entering the upper cockpit). "
Carl N.
Arlington, WA (KAWO)
RV-8, 780 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
