Old 08-21-2019, 10:36 AM
lr172 lr172 is online now
Originally Posted by FORANE View Post
Tape works well at preventing rain erosion however...
It is hard to get the tape to adhere to the curved tip of the blade without buckling and failing in that location.
Due to the above, the tip is unprotected and erodes on the leading edge.
After one good flight through rain, my experience is the tape gets damaged to the point that it requires replacement.
I have an older 3 blade Catto on my garage wall due to too much leading edge damage flying through rain, mist, etc. If it were one of his newer ones with the nickel leading edge, I would likely still be flying it today.
I think this is an installation issue. I had that issue the first time I put tape on, but the second time has been 100 hours and no issue. It does separate at the very edge and Craig recommends a drop of super glue to hold it there.
To the OP, installation is straight forward. I got finger prints on the first attempt. Second attempt was much better. Like most things in life, practice makes perfect.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 08-24-2019, 02:46 PM
ALagonia ALagonia is offline
I put the LET on my three blade Catto prop today. Learning curve is an understatement. First prop looks terrible. Second prop almost as bad. Third prop is acceptable.
Question for those that have used the LET more than one time - how do I remove the tape without damaging the painted prop blade?
I simply can?t live with my installation of the first two prop blades but am terrified the paint will come off.
Help please.
Old 08-24-2019, 06:14 PM
Help please.
Pretty sure I just pulled it off. Heat always helps with this type of task and I may have used a heat gun to soften up the adhesive.
