Aircraft Spruce doesn't feel it needs to correct it's description for the Saf-Air M12175 quick drain. Their description says it will fit the Rotax 912 engine when in fact it doesn't work on the late models due to a baffle change from the Rotax factory. It fits but you only find out the baffle prevents the drain from opening later when you try to drain the oil.
They revert to "It's up to the customer to ensure it is suitable for your application" for customer satisfaction.
I purchased two for my Aircam and there is insufficient space for the spacer they would be glad to sell you to make it work. They do list the spacer so they are aware that the condition exist. I only asked that they correct their suitability list to which no change has been made so be aware of this if you have a late model and wish to purchase this quick drain.
