-POSTING RULES
-Advertise in here!
Keep VAF Going
Donate methods
Point your
camera app here
to donate fast.
Old 10-29-2020, 07:31 PM
keith6261 keith6261 is offline
Default Engine size Pros and Cons
Guys, I trying to decide what engine size for my 8.
Old 10-30-2020, 01:19 AM
gasman gasman is offline
Based on Van's latest prices, The O360 is the same price as the O320.
So...... at least get the O360.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
Old 10-30-2020, 01:48 AM
rv8ch's Avatar
rv8ch rv8ch is online now
Default Mission?
I guess if we knew more about your "primary" mission it would help. Racing? Aero? Cross Country flying? Assuming you want a "normal" RV-8, get the exact engine/prop Van's recommends and your build and test time will be faster and easier.
Otherwise, anything from an 0-320 to an IO-540 will work, with tradeoffs.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 10-30-2020, 06:28 AM
Desert Rat Desert Rat is offline
I just went through this exercise.
Spent hours online and with the calculator, looking at everything from fuel burn, to expected KTAS, to range profiles, to the price of replacement cylinders, to perceived difficulty of each installation. Carefully reviewed each response to my VAF thread where I asked for opinions.
I finally just said heck with it and bought the Thunderbolt IO390.
Probably can't justify it for my mission, But it's ultimately what I wanted.
Where I'm going with this is that you can ask for internet advice and crunch numbers all day long, but ultimately you have to make a decision you can live with and it may not be the most practical one. Only you can decide.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 10-30-2020, 07:44 AM
Mel's Avatar
Mel Mel is offline
Desert Rat is exactly right. Unless you have a specific operating purpose, Van's recommended engine is usually the best option. More hp will give you more take-off and climb performance (As if the RV needed this), usually at the cost of money & weight, but very little, if any, cruise speed advantage.
Also, as Desert Rat points out, It's your airplane and it's experimental. If you want something in particular, do it!
Mel Asberry, DAR since the last century.
EAA Flight Advisor/Tech Counselor, Friend of the RV-1
Recipient of Tony Bingelis Award and Wright Brothers Master Pilot Award
USAF Vet, High School E-LSA Project Mentor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-30-2020, 08:25 AM
Default Just me
But I chose the injected version of the Lycoming for two reasons: easier lean of peak operation, and no carb icing issues.
It seems the price difference is small. Also, it is amazing how many builders initially fly with a carb engine and than upgrade to fuel injection.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
Old 10-30-2020, 02:55 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
Default Engine size?
Easy answer. Big as you can afford that the airframe can handle. You can never have enough horses under the hood. Fuel economy is only a small factor. I love the bigger horses and fuel injection is necessary for good life in the air.
I would buy the I0-360 because it will fly and sell faster when the time comes.
Enjoy spending the money cause it is gonna be quite a bit. Art
Old 10-30-2020, 04:47 PM
tjo tjo is offline
Just my opinion, of course, but best HP/$ is O360. Injected, if you want. The only reason to go angle valve is to go O390. There is no reason to go O320 unless you find a great deal. Simple formula, direct result
Tim
Old 10-30-2020, 05:10 PM
RYOUNG RYOUNG is offline
Desert Rat nailed it! I too originally planned an O-360 for my RV-8. Then after Van’s approved the IO-390 for use I was torn. After mulling over pros and cons for about a month, I bounced it off a good friend and his advice was “if you’re going to be a bear, be a grizzly”. That did it, along with the upcoming price increase. Now in the process of swapping out lower cowls with Van’s. Not looking back, full speed ahead. After all, what are friends for?
Robert
RV-3B Flying
Wagabond Flying
RV-8 Tail completed, QB Fuselage in progress
Old 10-30-2020, 08:35 PM
So my mission would be some light aerobatics but mostly cruising. Just wondering what true speeds are seen between an IO360 to a IO390. Thanks for everyone's input.
