Go Back   VAF Forums > Main > RV Building Tips/Techniques
  #51
Old 11-11-2019, 12:54 PM
airguy's Avatar
airguy airguy is offline
Originally Posted by RandyAB View Post
I?m interested in how one defines ?binding?? If an elevator moves freely with no discernible resistance by hand but has JUST enough friction in the system to resist gravity when held at a certain point, is that elevator considered bound?
If you can push it with a finger and it keeps moving when you remove the finger (either way up or down), it's good.
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 650 hrs and counting! IO360, SDS, WWRV200, Dynon HDX, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
Old 11-11-2019, 03:10 PM
RandyAB RandyAB is offline
What if it keeps moving but stops before reaching the mechanical limit?
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 11-11-2019, 03:51 PM
airguy's Avatar
That's a judgement call - you want low friction, there is no such thing as no friction. If you have a little binding action there the autopilot servos will be continually bitching about trim as they fight it.
I had mine adjusted perfectly prior to paint - then after I had it painted and reassembled (their A&P, not me), I quickly noticed that the autopilot was not happy and started investigating. Took me a couple hours to get the spacing washers back the way they were prior to it going to the paint shop - they clearly paid no attention to that on disassembly.
Old 11-11-2019, 04:10 PM
I agree about the judgement call. My setup has no palpable resistance when I manually move it and it will continue to move if I let go under its own momentum but it doesn?t free fall all the way to the low point if i don?t impart some small amount of energy. I am satisfied with this.
Randy P.
1st time builder
Reserved:C-GRPY
Old 11-12-2019, 11:51 AM
rvbuilder2002's Avatar
Having a low friction level in the elevator circuit is not of high importance for autopilot operation (though I imagine if it was severe enough it could impact that).
It is because it takes only a small amount of friction to have an influence on stick free pitch stability.
Think of it this way....
The elevator trim tab has a very small amount of influence on the elevator when it is just slightly deflected (as is typical in cruise flight).
It takes only a small amount of friction in the elevator circuit, that when the stick is bumped in the cockpit or the airplane flys through light turbulence bumps that cause a slight displacement, it doesn't return to the exact same position it was in before the event.
When this happens the airplane will no longer be in trim. Each time the elevator gets displaced it may return to a different static position depending on which way it move and how strong the displacement force was.
That is the primary reason that the elevator should be very free. Roll and yaw is important as well but to a much lesser degree than pitch.
I see lots of flying RV's with way more friction in the elevator control circuit than they should have.
BTW, on an RV-6,7,or 9, if the friction is very low the elevators will actually want to move towards the full up position because with the way the control column is hinged, its mass tends to make it sag downward (which moves the elevators towards the up position).
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 11-12-2019, 03:52 PM
Thanks for the explanation Scott. You would think that the slipstream would overcome some minimal friction to keep the plane at whatever speed it was trimmed for. So, by “very free” does that mean that it always should fall to exactly the same place when not supported? I’m sure that it can be accomplished but I also can’t help but think that once it is joined to the push pull tubes that there would be some degree of friction in that hard linkage that would be magnitudes greater than a minuscule amount of friction at the elevators.
Randy P.
1st time builder
Reserved:C-GRPY
Old 11-12-2019, 10:17 PM
So, by ?very free? does that mean that it always should fall to exactly the same place when not supported?
No
The check that has been described by others in this thread is a good one. Flick the elevator hard and it should stay in motion for a bit (bounce off the travel stop and revers direction).
Friction can be induced at many places in the system. It is often an additive result of a small amount at a few different locations.
One very common source in the side by side RV's is the two bearings that the control column pivots on. The brackets are very stiff and if not shimmed carefully it induces a side load on the bearings which causes system friction.
Scott McDaniels
Hubbard, Oregon
Old 11-13-2019, 09:09 AM
.........The check that has been described by others in this thread is a good one. Flick the elevator hard and it should stay in motion for a bit (bounce off the travel stop and revers direction).
Ok that is helpful. I must have missed that post in this thread.
Regarding the control column, I’ll have to go back in the plans and look. I don’t recall any special shimming being requested aside from the bearings between elevator horns and the bearings the horns articulate with.
Randy P.
1st time builder
Reserved:C-GRPY
Old 11-13-2019, 09:21 AM
Default Me
When i shimmed up the control column i did itper the instructions before the spar was riveted in. Now a year later i installed for a final time. One side required a ?L?
Washer, the other didnt. This will be very hard once the spar is installed.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 25% working canopy
Electrical 5%
Firewall Forward 5%
