Cleveland 30-59E O-rings
Plummit
Does anyone know if there is a Viton O-ring for the Cleveland 30-59E wheel cylinder? The stock O ring is Part #101-5200 MS28775-224.
-Marc
Yes The Viton ORings I run successfully in the RV10 calipers are one and three quarters inside diameter & two inch outside, so 1/8 thick. Available from Hydraulic Maintenance Shops. Much more user friendly as far as heat resistance.
McMaster is great!!
Marc,
Glad to help out. If you have the EAA's version of SolidWorks, you can download a ton of great CAD models of most of the things that McMaster carries on their website. Although they don't carry much of the AN hardware we typically use, you can usually modify their CAD models to match the specs for the hardware that you need. I find it's a great time saver!
Jeff
