Looking for Guidance on Cowl Attachment
lr172
On my 6, I used the hinges on the lower vertical line and the horizontal line. I used screws and tinnermans on the upper and lower firewall attachments. While I will definately use screws on the bottom, I am wondering how many folks are using the hinges on the upper cowl attachment at the firewall. Is it holding up over the years? Any problems getting the pins in or out? Or am I best to go with screws or camlocs?
Thanks for sharing your experience.
Never liked the look of screws or camlock on the cowl (to each his own).
I used hinges with the following mods:
- On the top, instead of using the 3/32? pin in the 1/8? hinge, I used a 1/8? SS pin that I trimmed down to 3/32? on the last 10-12 ? or so. This allowed for the pin to still go in and make the bend, but it mitigates the cowl bulging up on air pressure at the top.
- On the bottom I used the MS20001P extruded hinge instead of the provided hinge. This hinge is far more robust and solves the typical issue of hinge eyes breaking off on the bottom hinges from vibration.
All is well after 500 hours.
If you don?t use the the extruded hinge on the bottom, use aluminum plate and nutplates.
- On the top, instead of using the 3/32” pin in the 1/8” hinge, I used a 1/8” SS pin that I trimmed down to 3/32” on the last 10-12 “ or so. This allowed for the pin to still go in and make the bend, but it mitigates the cowl bulging up on air pressure at the top.
If you don’t use the the extruded hinge on the bottom, use aluminum plate and nutplates.
Thanks Carl. I like the idea of the extruded hinge.
I am pretty sure the RV-10 plans specify use of 1/8 pin at the upper portion of the firewall.
While I will definitely use screws on the bottom, I am wondering how many folks are using the hinges on the upper cowl attachment at the firewall. Is it holding up over the years? Any problems getting the pins in or out?
I purchased flying, I did not build my 6a. It has hinges all but bottom. Built in 1992 and no records or evidence of it ever being anything different. Tony Bengilis built the 6a I own. I have on one occasion had a little bulge top/right, so I can attest that can happen. The recommendation of larger wire likely would address that.
Skybolts
I was planning on using skybolts on the firewall and hinges on the sides...until I flecked the hinge in place and attempted to push 30+ inches of wire through all the knuckles, twice. That was enough for me. I went with all skybolts and never looked back...
Ask around, there are quite a few people who did the hinges that wish they hadn?t...
Page 47-7 specifies 0.090? pin material for this, not 1/8?.
Reread my post. The 1/8? pins are filed down on the ends so they make the bend. They are full size along the top flat parts. This takes out the slop that exists between the 1/8? hinge eyes and the standard 0.90? pins along the top so under pressure the cowl does not bulge up.
I did what Carl did and 850hrs later they still look good. I can tell you that the first few times it took a drill to spin the pin into the hinges.
Reread my post. I was responding to Scott. :)
The hinges work very well between the longitudinal seam. They work very well vertically on the sides of the bottom cowling. Many people have found them nice across the top.
Personally, most of the RVs I've worked on have screws or 1/4 turns across the top and bottom of the firewall.
Hinges across the top are difficult to install on many aircraft. Hinges across the bottom tend to break the hinge eyelets starting at the air outlet.
This is my experience working on RVs for over 30 years.
I noticed yesterday that I have .090?s on the top bends and on the sides (upper and lower attachment). The lower cowl at the firewall is .125?s.
No issues after 160 hrs despite the slightly smaller than suggested side pins. I do wish I had used extruded hinges though. I haven?t had any problems yet, but would like the longer-term confidence of having extruded pieces.
I have been considering dressing the pins with valve grinding compound and rotating them with a drill to help open up the travel-tunnel a bit. One of these days, I might try it.
The hinges that I have for cowl have .125" holes and may try your trick with the modified .125 pins. However, the extruded hinges that aircraft spruce sells all have .090 pins, even in the thicker versions, which I assume that I would want for the bottom. Is this what you used or did you find something with .125 pins?
The result of an apparent miscommunication, because both of the RV-10 prototypes have been flying with 1/8" pins (actually .115") at this location since they were built.
It works quite well since if built per plans, the pins insert at the top mid point of the firewall.
Thanks to all for the input. Much appreciated.
I can't wait to get past this top/doors!! Almost there though.
