-POSTING RULES
-Advertise in here!
Keep VAF Going
Donate methods
Point your
camera app here
to donate fast.
Old 10-26-2020, 04:42 PM
ten4teg ten4teg is offline
Default Garmin G5 Static - Altitude
Just got a Garmin G5. When I set the Baro to field elevation, the baro does not match the current pressure. It looks like it needs adjustment. Anybody know a way to do this? I don't need IFR accuracy. Thanks tom.gregorski@gmail.com
Old 10-26-2020, 04:43 PM
bkervaski's Avatar
How far off is it? Mine is off like 10 feet.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-26-2020, 05:17 PM
Default Reply
Mine is off about 70 feet.
Old 10-26-2020, 07:33 PM
Walt's Avatar
Walt Walt is offline
They can easily be calibrated with a (high accuracy RVSM preferred) pitot static test box, you have to take it up to 20K for the cal procedure. I find they can drift a bit but have not seen anywhere near 70'.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs, New Titan IO-370, Bendix Mags
Old 10-26-2020, 08:13 PM
Desert Rat Desert Rat is offline
Not saying it's right, because a 70' error would really bother me as well, but even for IFR the allowable error on an altimeter is shockingly large. Going out on a limb here, but I seem to recall the AIM talking about +-75'. Does that sound right?
Also, is it possible that the error isn't actually that large? My home runway looks dead flat, but according to the approach plates, field elevation is 1408, measured at the threshold for rwy 19, and drops about 40' by the time it gets to the other end. The runup pad (about midfield) consistently shows 20' lower than published field elevation, which seem logical based on what the plate shows.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 10-26-2020, 08:20 PM
MacCool MacCool is offline
I added a G5 to my panel as a backup, in addition to my AFS EFIS and to the old round gauge still in the panel. I just had the entire suite IFR-certified. Interestingly, the EFIS and the G5 were exact, and matched. I still have to set three different altimeters, but the old round gauge didn't make the cut and got placarded as "VFR only".
Old 10-26-2020, 08:41 PM
newt's Avatar
newt newt is offline
When you have one altimeter, you always know exactly how high you're flying.
When you have two, you're never quite sure.
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 10-27-2020, 08:07 AM
Walt's Avatar
Allowed error (91.411) depends on altitude.
With 2 altimeters the split could be double the error if one was on the minus side limit and the other was on the positive side limit.
ALTITUDE / ERROR
0 / 20
500 / 20
1,000 / 20
1,500 / 25
2,000 / 30
3,000 / 30
4,000 / 35
6,000 / 40
8,000 / 60
Old 10-27-2020, 08:12 AM
Thanks Walt!
Terry Shortt
Fuselage in process
#72651
Old 10-28-2020, 08:28 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G5 Calibration
Tom,
While there is a static cal procedure provided in the installation manual, you should not have to perform it right out of the box. Reach out to us via email at G3Xpert@Garmin.com and we can get an exchange set up for you if you would like.
Justin
Garmin G3X Support
g3xpert@garmin.com
Last edited by g3xpert : 11-02-2020 at 02:17 PM. Reason: Addressed incorrect username in original response
