Old 11-04-2019, 05:25 PM
cubdriver cubdriver is offline
Cool JDAir Canopy Latch
Thinking about installing the JDAir Latch. Does anyone have a template they have created for the RV14 that they can share? Is it worth doing?
I know a few things are different from the RV 7/9 plans provided.
Thanks - Jim
Jim Potter - Ramona, CA
RV9A Owner- landed it at Osh on yellow dot
Previous Owner of 1940 J3 Cub
Currently Building RV14a
jim.potter@cox.net
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight." - Elrey B. Jeppesen
Old 11-04-2019, 06:43 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default With latch
http://www.vansairforce.com/communit...ighlight=Jdair
It?s a relatively simple mod and you can print a template off there website for the two holes. I found it almost easier to move the lower flange then just trace the actual handle for the two large cutouts.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 08-01-2020, 08:05 PM
avatty avatty is offline
Did you make new angles (3/4x3/4x.063) as in the current JDAir drawings? From the photos it looks like you used the Vans parts or something else, as the photos show something you could crimp.
Thanks for the information!
Tom
Walnut Creek, CA
RV-14 slow-build
Empennage kit completed
Wing kit completed
Fuselage kit progressing
Dues paid for 2020
Old 08-02-2020, 12:20 AM
Swiss14A Swiss14A is offline
Hi
I just finished the KD latch. Made new angles and tested on scratch (which was good, especially because I made a lock as well). With new angles you can testfit the whole assembly including latch and angles and then matchdrill the upper angle from the skin. I figured this is easier than using the stock angles and match everything else...
Click image for larger version
ID:	703  Click image for larger version
ID:	704  Click image for larger version
ID:	705  Click image for larger version
ID:	706  Click image for larger version
Alexandra & Fabian
RV14 HB-YAF, in progress
Old 08-02-2020, 07:23 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Locking details?
Do you have any diagrams or pics of how you prepared the latch lever for the rotating lock? And, the item name/number of the lock itself?
Looks like you may have milled a notch into latch lever and the upper angle.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
1946 Bellanca Cruisair 14-13-2 (73 YRS OLD 8/15/19)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/1/19 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old Yesterday, 03:55 AM
I just did a few attempts with the file and bending the angle, no big engineering behind And yes, I filed a slot into the angle and also made the already existing slot in the handle bigger to accomodate the locking angle. Just be careful that you have the position of the lock right. Between the Door latch and the upper longeron assembly. You need free 180 rotation of the lock.
https://www.aircraftspruce.com/catal...rolocksets.php
this is the lock I used
Alexandra & Fabian
