Old 10-14-2019, 09:10 AM
Originally Posted by psalys View Post
I'll try squeezing the left flapperon and see if the symptoms improve.
I did the flaperon trailing edge squeeze and wasn't happy with result. What works really good is to raise/lower entire flaperon with the rod end pivot bearings. Try 1/2 turn in/out and see if it affects heavy wing.
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 585
LSRM-A Certificate 2016 for RV-12 N633CM
Old 10-15-2019, 10:50 PM
psalys psalys is offline
Default That's an interesting idea Jim
I had to get out my KAI to see what you were talking about.
Thanks for the suggestion.
Patrick
RV-12iS complete and flying
Old 10-16-2019, 08:15 AM
rvbuilder2002's Avatar
I always suggest people keep in mind that there are a lot off different things that can cause a roll imbalance.
Arbitrarily choosing one (adjusting rod ends) without investigating whether the adjustment they are about to make is actually causing the problem, may solve the problem, but only by inducing an additional problem the happens to counter the first one.
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Scott McDaniels
Van's Aircraft Engineering Prototype Shop Manager
Hubbard, Oregon
Old 10-19-2019, 04:38 AM
dwmillsap dwmillsap is offline
Adjusting the rod end bearings will start you chasing your tail. Ask me how I know. Haha.
Smashing the trailing edge of the flaperons will absolutely have an effect, but tread lightly because it takes very little to make a lot of difference especially the further outboard you are.
On my RV-12 I?ve noticed that it matters how much fuel is on board or whether or not I have a passenger or luggage (tools). So, be sure all of your observations are correct before you start changing things. These are great little aircraft so have fun!
Good luck.
Dennis W. Millsap
Retired Air Force
RV-6A built, flown and sold
RV-10 built, flown and sold
RV-12 built and currently flying
EAA Technical Counselor and Flight Advisor
A&P
Old 10-19-2019, 02:41 PM
Good luck.
/\ this, Absolutely. I can take my friends RV-12 while sitting in the passenger side at 255# to a heavy right wing, just by shifting my upper body over to the right 3 or 4 inches.
Old 10-20-2019, 02:25 PM
Tacco Tacco is offline
Ditto what Dennis and Scott said. I'm a card caring member of the "chasing your tail club".
Changing any dimension of the control linkage is a risky and probably futile proposition. Changing push rod lengths (one side) only changes to relationship of stick position to neutral flaperon position, changing both sides only raises or lowers the flap positions at neutral. Then there are the interference issues: control stick interference with the nuts on the electrical cable run hold down block, push-rod interference with the electronic fuel pump. You might also end up with an over-center (or less than optimum) orientation of the flaperon torque tube arms. Changing the rodend bearings out on the flaperons to raise or lower them will certainly change something, but will also change the alignment of the flaperon with the torque tube attachment point.
I'd ensure all your dimensions are per plans, then focus on the trailing edge. Takes some patience. Some people have also had luck with ensuring the flatness of the top wing skin aft of the aft spar where it meets the flaperon.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
Old 10-20-2019, 03:15 PM
Default Thanks for the suggestions
I have been checking and adjusting the flapperons and the upper wing skin trailing edge. Now the other wing (left) is slightly heavy and my right wing drop with stalls is much less severe. I will continue to make small adjustments and try to get it tuned just right.
Thank you all.
Patrick
Old 10-20-2019, 09:30 PM
Try taping a piece of string to your canopy to act as a yaw string. If it is straight along the longitudinal axis and the ball is centered in flight it is rigged properly.
I wish I could claim I figured that out for myself, but my old CAP cadet friend became an F-4 pilot. He got his glider license in CAP and learned about yaw strings. When he had to test an F-4 out of maintenance he would tape one on the wind screen. He said they were good up to about 200 knots after which they were gone with the wind!
Old 10-20-2019, 09:46 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Yaw strings are used on virtually all sailplanes, and once in awhile you'll see one on a jet. But because of the propeller slipstream, they won't accurately work on tractor prop planes.
To coordinate, "Step on the ball, step away from the string!"
Carl N.
Arlington, WA (KAWO)
RV-8, 755 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 10-23-2019, 06:53 PM
Back to right wing drop upon stall: What are everyone's thoughts on the contribution of the landing light to the issue??
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2020 Donation Paid
