Old 01-30-2020, 11:24 AM
TXFlyGuy TXFlyGuy is offline
Default Specific Fuel Consumption
What is the BSFC of a Lycoming or Continental engine?
Just for comparison, my V8 is between .40 and .50, with an average burn of .45.
Here are the latest numbers from the dyno runs...
4000 rpm:
24 inches = 345tq 260hp 19.5 gph
22 inches = 324tq 246hp 18.7 gph
21 inches = 303tq 235hp 16.2 gph
3500 rpm:
24 inches = 335tq 220hp 16.5 gph
From 4000 to 3500 the torque values are about the same but the hp drops about 40.
This comes in right at .45 lbs / hp / hr. Right on schedule for a high performance V8.
Annual dues paid - 6-13-2020
Old 01-30-2020, 11:34 AM
Grum.man Grum.man is offline
The IO-550 line gets around .37-.38 LOP at 75%
Old 01-30-2020, 11:50 AM
What is the hp/torque at 75% power? RPM / Manifold Pressure?
Is that pounds per hour per horsepower? If so, those are awesome numbers. We will not run LOP.
Old 01-30-2020, 11:56 AM
232 HP for an IO-550N. Fuel flow at 75% best econ is 88-90 lbs per hour. TQ isn't specified but calculated should be about 488 lb-ft
The IO-550G is better but is only 210 HP.
Old 01-30-2020, 12:50 PM
Impressive numbers, nearing diesel fuel burns. My numbers in the first post are at full rich (I think). I doubt that any leaning was done during the dyno runs.
Old 05-04-2020, 11:22 AM
dlomheim dlomheim is offline
Default Diesel Engine BSFC?
Aren't Diesels more in the range of .26-.32?
Doug
RV-9A FWF / Mazda 13B
Old 05-04-2020, 07:31 PM
BillL BillL is offline
Yes, except for automotive.
Bill
Old 05-04-2020, 08:41 PM
scsmith scsmith is offline
What ECU are you using? Most modern automotive engines run pretty lean at mid-power. WOT, I'm not sure. Ross could chime in here.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 05-05-2020, 05:30 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default 550G/N specs
Using the std TQ/HP formulas, the 550N has 603lbs/ft of torque at 2700/30” where the Lyc 540 has 505lbs/ft at the same power setting. That is a substantial differrence.
I am pretty sure that the TCM 360 has 210HP - but at 2800RPM? Not sure.
The TCM 550G (280HP/2550RPM) can be converted to the N specs (310HP/2700RPM) by turning the little screw on the prop governor...
HP/Torque calculator: https://spicerparts.com/calculators/...que-calculator
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 05-16-2020, 09:36 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Originally Posted by dlomheim View Post
Aren't Diesels more in the range of .26-.32?Doug RV-9A FWF / Mazda 13B
Diesel is up to 20% to 30% more efficient and the fuel has 10% to 15% more energy density, and makes more low end torque than a petrol engine.
I drive a VW TDI Sportwagen and can get over 50 mpg highway, and it is a hoot to drive with low end torque starting from idle is 100% torque at 1750 RPM and stays flat as a board (in part due to torque limiter in computer, these cars can be uncorked).... Low speed around the corner acceleration is fun. Why not diesel in airplanes. Of course they have some. The issue is weight. Diesel engines are beefy to handle the pressures. Also certification cost.
The answer is Lycoming is supiror to any alternative engine... proven over and over.
The HP, FF, BSFC, charts are in the Lycoming manuals. This is for a Continental, BSFC looks like 0.38 is lowest.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
