Rudder horn hole elongation
stigaro
Started to work on my RV-14A rudder recently and while final drilling the rudder horn (R-405PD) to bottom rib/spar assembly, I noticed my holes were slightly elongated (between 0.010" to 0.020"). Not sure how this happened, but I know this is out of spec for AN470AD4 rivets (0.125"-0.135" hole size). Anyone know if this is still OK or if it's possible to drill these out to AN470AD5 rivets? Or should I just scrap these and do them over? I have sent an email to Van's as well, so hoping to hear back from them soon.
Non-Van's answer: Use a longer rivet to fill the hole. Rivets are good in that they expand to fill the hole, but you'll need the extra material to ensure a proper shop head.
Good to know about dull drill bits doing this. I used a new #30 spiral reamer for this but I wonder if the holes were a bit smaller in the rudder horn compared to the thinner sheet material and as a result the reamer tended to wander a bit going through the horn. I did notice the reamer seemed to cut out more material than I thought it should have at the time.
I have seen a lot of this, and the engineers at Vans usually suggest if the edge distance is sufficient, and the material is thick enough, go with the oversize rivet.
Gary
I had just this on my elevator. I ran it past my inspector (I’m in the U.K.) and I drilled the holes out round and went up to the next size rivet AN470AD5.
surprising to read a reamer did these holes. the purpose of a reamer is a round hole. the problem must be in the drilling operation/drills as suggested.
holes must have already been too large when the reamer got there.
What did Van's say about this? I did pretty much the exact same thing with my reamer, despite trying hard to keep the drill square. I have some AN5 rivets on order.
How are you experience folks avoiding elongated holes when drilling through thick layers? I've got another one on the horizontal stabilizer doubler when match-drilling the inboard nose ribs. Frustrating.
Make sure you are spinning the drill bit as fast as possible - that's what's nice about the air drills - they turn fast. And of course use good quality, sharp bits.
Worst case scenario, the holes are spaced far enough apart, when doubt, you can use AN-5 rivet, no worries!
DAR Gary
