Evening,
I have an Aera 560 which is mounted in my panel, and I've got the bare wire harness to provide power to the unit as well as grab the GPS signal from it. Those both seem to work well.
Now I'm trying to get the audio into my PMA8000, but no matter what I try I can't get the darn thing to hard wire in. Using a mini jack to plug into the PMA works fine.
Has anyone successfully hard wired an Aera to a PMA8000?
If so, can you share how you wired the bare wire audio outputs to the PMA8000?
Thanks!
Thanks!
