Old 05-12-2019, 09:44 AM
FinnFlyer FinnFlyer is offline
Default Transponder check
Any recommendations for whom to do a 24-month VFR transponder/static check (FAR 91.413) near Gainesville, FL?
I can easily do it myself, but apparently not allowed to.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 05-12-2019, 11:09 AM
JTJones's Avatar
JTJones JTJones is offline
Default Jesse Saint and gang - Marion County
I?d imagine Jesse Saint can do it at Marion County (X35)
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2020 VAF dues paid plus beer money😜
Old 05-13-2019, 08:11 AM
Unfortunately Jesse says he can't do that check.
Still not sure that I really need it.
"Appendix F to Part 43 - ATC Transponder Tests and Inspections
The ATC transponder tests required by § 91.413 of this chapter may be conducted using a bench check or portable test ..."
It's a factory new Stratus 1090ESG that comes with a FAA Form 8130-3. Presumably it was tested at factory to meet Appendix F requirements.
So I shouldn't really need a new check for another 24 months from the date on the form.
Finn
Originally Posted by JTJones View Post
I’d imagine Jesse Saint can do it at Marion County (X35)
Old 05-13-2019, 09:11 AM
flyinga flyinga is offline
Did the factory send you the logbook sticker showing that the test was done?
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 05-13-2019, 09:28 AM
Bicyclops Bicyclops is offline
Default (b)
? 91.413 ATC transponder tests and inspections.
(a) No persons may use an ATC transponder that is specified in 91.215(a), 121.345(c), or ? 135.143(c) of this chapter unless, within the preceding 24 calendar months, the ATC transponder has been tested and inspected and found to comply with appendix F of part 43 of this chapter; and
(b) Following any installation or maintenance on an ATC transponder where data correspondence error could be introduced, the integrated system has been tested, inspected, and found to comply with paragraph (c), appendix E, of part 43 of this chapter.
(c) The tests and inspections specified in this section must be conducted by -
(1) A certificated repair station properly equipped to perform those functions and holding -
(i) A radio rating, Class III;
(ii) A limited radio rating appropriate to the make and model transponder to be tested;
(iii) A limited rating appropriate to the test to be performed;
etc.
paragraph (b) tells the story - after installation, integrated system. That means encoder and antenna and all. I don't think the transponder manufacturer's bench test will make you legal.
Ed Holyoke
Old 05-13-2019, 10:07 AM
Ed and Jim,
I think I've now read all of the transponder check threads.
And, although this is not a "new" installation in terms of cable and antenna, I do believe you're right.
So, any recommendation on where to get it done in North/Central Florida?
Finn
Old 05-13-2019, 11:37 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Finn, check you PM's
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 05-13-2019, 12:08 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Call Volusia Aviation (386-795-1189), Central Florida Avionics (352-787-0712), Bragg Avionics (904-564-1717) or Southeast Aero (904-824-1899) for the check. Volusia and Bragg might travel to your location or meet you somewhere.
If you wind up doing it at KSGJ, (Volusia, Bragg or SE Aero) let me know and we can meet for lunch.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 05-15-2019, 12:52 PM
Thank you for all your replies and private messages!
Closest for me will be Quest Avionics in Ocala (OCF).
Scheduled for earliest available time: next Thursday.
I found and fixed my static leak. The plastic T between static ports and static line. Unbelievable that it would start leaking. Tough place to get to: had to remove battery, elevator push rod and bell crank to put a piece of OSB resting on lower longerons to rest my elbows on.
Finn
