Numatx set up
Jskyking
Just received my numatx squeezer. At first glance, it looks like the air supply hose from the compressor to the footpedal will be constricted. I?m trying to avoid modifying the foot pedal housing. Hopefully, there?s a solution that avoids alteration. Any ideas are appreciated.
Jy
Mine is similar - junk that piece of yellow plastic, we aren't in kindergarten ;)
Set mine up as per the arrangement that Vince had on his stand.
Pressure settings
Hi,
Found 35 psi for 3/32 rivets and 70psi for 1/8th.
Once set it is brill perfect squeezing every time.
Duncan
On mine:
3/32 is 46psi
1/8 is 86psi
Gauges can vary a decent amount but as long as you can set yours to the same value each time then the actual number shouldn't matter.
Jared.
Mine
On mine:
3/32: 44 psi
1/8: 78 psi
I love this tool! Just be careful not to accidentally step on the switch :eek:
Interesting - manual says ? NEVER operate the system below 60-pisg or above 90-psig air pressure.?. Ok, I understand the max air pressure limitation, but why the 60 psi warning? Sounds as though 30 to 45 is what?s needed to operate.
