Old 08-02-2019, 09:01 AM
sglynn's Avatar
sglynn sglynn is offline
Default GDL 39 Power chord
Is the power chord for the GDL 39 just two wires so that I could cut the cigarette light adapter off and hard wire it to power and ground?
thanks
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 08-02-2019, 09:47 AM
lr172 lr172 is offline
Yes
Yes
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 08-02-2019, 03:31 PM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
Originally Posted by lr172 View Post
Yes
Yes
What he said. Had one hard wired into mine for a while.
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Donated dollars - 2019
Old 08-03-2019, 01:53 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default Depends if you need a hard data line
The GDL39 specific hard wire/data cable also has a RS232 data line to interface with portables such as the 796 in my case, you can use Bluetooth but the 39 only allows 2 BT connections so you limit your choices a bit. If you just want the power connection then you can connect as you described.
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
