NMEA fast or slow
dothetime
I just updated my gps, NMEA fast or slow to Dynon D180?
Can’t find it in the Dynon manual.
Updated from an obsolete 496 to an almost obsolete 560
NMEA
Thanks, but I’m referring to the Garmin 560 setting for the autopilot.
There are two, fast or slow.
Terminology confusion? NMEA usually refers to an RS232 format, where the speed (baud rate) is set independently (e.g., 9600). OTOH two wire ARINC data standards usually offer ‘fast’ or ‘slow’.
It is not the baud rate. In the garmin portable world, the NMEA fast or slow determines the interval of how often the NMEA data payload is sent. It also changes the specific content of what data is sent in each transmission (fast includes fewer data elements). I once resolved a connectivity issue by changing this setting.
^^^^^^THIS^^^^^^
FWIW; use the "slow" setting unless you have a specific reason to use the "fast" one.
:cool:
