Old 09-02-2018, 12:15 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Default ADSB out check report from FAA
Greetings
I finished the install and configuration of my uAvionix Echo/GRT SafeFly gps unit the other day and have now done two flights. Everything seems to be working great, I?m getting weather and traffic, but there is no way of checking the out function from the plane, so I sent a report request via the FAA website. The email I received back from them says that my request failed to generate a result. Today I did another flight and checked in with Santa Barbara approach in flight and asked them to check. They responded that they had not yet been trained on ADSB but that they were receiving data from me and as far as they could tell it was working fine. Upon landing I requested another FAA report. Same ?failed to generate a result? response, which to me means that their system never saw me at all.
Any ideas?
Erich
Old 09-02-2018, 01:17 PM
Greg Dillon Greg Dillon is offline
Check FlightAware.com to see if you're 'in the system'. My buddy's 9A has ADSB and I can follow his flights from takeoff to touchdown, whereas I can only 'see' my plane if I'm on flight following.
Old 09-02-2018, 01:31 PM
Jesse's Avatar
Jesse Jesse is offline
The Echo is UAT. Flightaware and Flightradar24 track 1090ES. Make sure you get the right date in. Text me your plane info & date you flew & I?ll try to get a report.
Jesse Saint
Old 09-02-2018, 03:26 PM
As Jesse said, anytime after 5 pm Pacific is ?tomorrow? gmt.
Double check your N number and hexadecimal ICAO code are correct.
Old 09-02-2018, 03:32 PM
Jesse's Avatar
Make sure you have N2725R and hex code A2B101 in the unit.
Jesse Saint
Old 09-02-2018, 03:43 PM
I know date was right. Will double check N number and code in set up.
Old 09-02-2018, 09:10 PM
PCHunt PCHunt is offline
Also, if you have enabled "stealth mode" when squawking 1200, you won't get a report. Must be transmitting your N-number.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 09-02-2018, 11:34 PM
I have no idea how to enable stealth mode. I just followed the GRT / uAvionix manuals.
Erich
Old 09-03-2018, 06:26 AM
blueflyer's Avatar
blueflyer blueflyer is offline
I wasnt getting reports like you. I had 2 issues:
1)I mention this only to help you in your process in ruling things out because I have a 400W and you have a GRT. Turns out that I had not setup my 400W correctly. I had incorrectly told my 400W which wire was supposed to be talking to my Echo (in my 400W settings)
2) I had fat fingered the wrong ICAO code into my echo configuration app, and therefore was not getting any reports.
Old 09-03-2018, 07:37 AM
Plummit's Avatar
Plummit Plummit is offline
Really? I just installed the GDL-88 UAT ADSB device from Garmin and my plane showed up on Flight aware squawking 1200 and not talking to anyone!
-Marc
N814RV
2020 Donation Made
