Old 12-07-2019, 11:28 AM
amaris amaris is offline
Default Steel AN fittings on firewall?
I'm not sure where to post this, so I'll put it in my model type, but applies to all.
I'm concerned about using aluminum AN fittings (or any important aluminum components) in FF so people recommend steel. I've not seen stainless steel fittings, just steel. Is there not concern about galvanic corrosion between the stainless and the steel? Or does the benefit of steel on FF outweigh the risk of corrosion?
Thanks.
Allen Maris - 2020 Dues paid
7A - 544RV In Progress
Santa Ynez, CA
Old 12-07-2019, 12:12 PM
rv8ch's Avatar
rv8ch rv8ch is online now
Default steel
I used all steel FWF and it is black with some kind of anti-corrosion coating. Seems to be the standard.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-07-2019, 01:01 PM
Another never ending debate---Vans uses aluminum in some cases, and steel in others. We like stainless, but its a bunch costlier (?).
Personally I thinkn that if you had a fire hot enough to melt 2024T3 aluminum, then a lot of other things would go first.
Tom
Ridgeland, SC
Old 12-07-2019, 01:13 PM
scsmith scsmith is offline
The primary purpose for steel fittings FWF is for fatigue resistance in vibration environments. I use steel (or stainless) exclusively on the engine. On anything mounted firmly to the firewall, I will still use aluminum for large-size fittings.
Fire will likely burn through thin aluminum items (like a firewall-mounted cabin heat control valve) but in the time it would take to melt an AN fitting? A lot of other bad things will happen long before that happens.
One caution of using stainless fittings -- a stainless B-nut on a stainless flare fitting can seize and gall. Use a very light coating of nickel anti-seize.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 12-07-2019, 02:43 PM
rapid_ascent rapid_ascent is offline
Allen,
Stainless fittings are available at Anplumbing.com among other places. They are more expensive, but I went ahead. I have my brake and fuel line bulkhead fittings in stainless. No aluminum passthrough of any type on my firewall.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-07-2019, 09:34 PM
Thanks, everyone.
I think I'll go steel. It's a bit more but at least it's one less thing to be concerned with. Though as Tom points out, if it gets bad enough to worry about melting the fittings, I'm sure there will be many other issues to deal with too.
Santa Ynez, CA
Old 12-08-2019, 05:47 AM
DanH's Avatar
DanH DanH is offline
Use stainless rather than an oxide finish or plated steel. We want bulletproof fuel systems, so corrosion performance is notable. I've done one AOG call with rusty fittings. I don't know what got into the tanks, but a lot of steel parts looked like Brillo pads.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-08-2019, 07:43 AM
acam37's Avatar
acam37 acam37 is offline
Steel and stainless steel JIC fittings can be purchased locally at just about any hydraulic shop. Most even carry braided SS teflon hose.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 12-08-2019, 12:22 PM
I did look at the JIC but they were essentially the same price as the AN versions. All look to be about $35-45 regardless.
Santa Ynez, CA
Old 12-08-2019, 12:48 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Probably goes without saying, but just a reminder to make sure you get AN (or JIC) fittings, not SAE. That is to say, 37 degree flares, not 45.
2019 Dues paid!
