Old 10-06-2019, 10:26 AM
subpar_bucker subpar_bucker is offline
Default Dye failure on canopy fiberglass
I just finished laying up the canopy fiberglass and unfortunately the view from inside is as green as all get out I have the canopy glare shield that I'm going to install later, but there will be sections of the greenery visible after that is installed.
I have gray dye from West Systems now. I'm wondering if it's possible/advisable to sand down close to the canopy these areas that are visible and recoat them with dyed epoxy? Alternatively I can talk to the painter I'm using and see if he can simply shoot these areas on the inside and cover them later.
Any advice appreciated.
Old 10-06-2019, 11:41 AM
RV10Pilot RV10Pilot is offline
At this point I like the paint option better. I feel there is too much risk sanding / grinding all the fiberglass away vs the reward.
Old 10-06-2019, 11:49 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I also started with dyed epoxy and it also didn't work out for me. Finished the outside than I taped the inside with electrical tape and painted the plexi. Looks great.
PH-BZT
MyKitlog
Old 10-06-2019, 02:16 PM
DHeal DHeal is offline
I used the same "wrap" material that I used for my instrument panel to cover up the areas you are concerned about. It looks fine after six years.
https://www.metrorestyling.com/3M-GR...p/dinoc420.htm
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 915+ hours (as of June 2020)!
VAF donation through June 2021.
Old 10-07-2019, 10:51 AM
If you?re talking about the seeing the back side of the fiberglass through the canopy plex I just masked off the canopy and spray painted the inside surface of the canopy to cover the area behind the fiberglass.
Old 10-07-2019, 11:35 AM
rcarsey rcarsey is offline
My buddy at my airport did this to his too and it looks fine. I can't remember if his was white or the external color of his plane.. just make sure your masking won't let any paint bleed through.. last thing you need is paint on your canopy!
Rob Carsey, North Brunswick NJ
RV-12iS (N713)
Tail 100% done
Wings 95% done (AOA)
Fuse 100% done
Finish 100% done (cowl)
Avionics 100% done
Dues paid 2019
Old 10-07-2019, 11:08 PM
My interior is grey except for the flat black glare shield, so it blended in just fine.
Old 10-08-2019, 08:12 PM
Thanks for the responses everyone! I'll go with the inside paint option.
Also, if anyone needs gray epoxy dye let me know. It turns out a bottle is enough for 100 canopies
