-POSTING RULES
-Advertise in here!
Keep VAF Going
Donate methods
Point your
camera app here
to donate fast.
Old 09-11-2019, 09:43 AM
Frankster13 Frankster13 is offline
Location: Sausalito CA in Northern CA near wine country
Default Cockpit Fire Extinguisher
I am looking into what type of fire extinguisher I should have on board. I am looking into a small Halon Fire Extinguisher. Is there any thoughts, ideas or consensus on the best option?
Frank Ketcham
Old 09-11-2019, 09:51 AM
bkervaski's Avatar
This is the one I see most often and I use - https://www.aircraftspruce.com/catal...ges/a344tc.php
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-11-2019, 10:20 AM
Bavafa Bavafa is offline
I am using the H3R FIRE EXTINGUISHER MODEL A344T which is the same as the model above but in Red which I like better, it is cheaper and with being red easier to identify and won't get nearly as hot in a RV cockpit.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-11-2019, 10:38 AM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Default Stay away from the A400!!
STAY AWAY FROM THE A400!! Spruce still sells the H3R A400 model which is the smallest Halon extinguisher you can get. There is no gauge on it and no provision to service it. They claim a 9 year shelf life and once a year you check the extinguisher by weight. Well this year I found mine to be empty during my 4th CI, well short of the 9 year mark. I contacted H3R and they told me it was a known issue and that they had stopped selling these units several years ago. They also mentioned that there had been two known explosions of these units, both in helicopters in Canada. Even so, many of these are still available through multiple vendors to include Spruce. Despite my unit being past their warranty period they were nice enough to give me a discount on a new A344 unit. Much sturdier, you can have this unit serviced and refilled, gauge makes it easy to check and the bracket fits the same screw holes as the A400. The unit is slightly larger but still fits the same spot in my -8. The only down side in my case is that the top now covers a power port I?ve got. Got plenty of room to relocate it, just have not yet. The A344 unit comes painted in red or they have a chromed out bottle too for a bit more $$.
Good discussion at this thread:
http://www.vansairforce.com/communit...t=Extinguisher
Here too:
http://www.vansairforce.com/communit...e+extinguisher
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 09-11-2019, 10:59 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default A344's
Just bought two A344's for the new 7. Now I've got to figure out where to mount them!!! Small, compact units that look good.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 09-11-2019, 11:25 AM
clam clam is offline
Default FWF extinguisher...
... not to hijack this thread, but in addition to the cockpit extinguishers discussed here, any recommendations for extinguishers plumbed into the FWF?
RV-8 KFYE
Memphis, TN
donation given
Old 09-11-2019, 11:51 AM
rzbill's Avatar
rzbill rzbill is online now
Originally Posted by Carlos151 View Post
STAY AWAY FROM THE A400!! Spruce still sells the H3R A400 model which is the smallest Halon extinguisher you can get. There is no gauge on it and no provision to service it. They claim a 9 year shelf life and once a year you check the extinguisher by weight. Well this year I found mine to be empty during my 4th CI, well short of the 9 year mark. I contacted H3R and they told me it was a known issue and that they had stopped selling these units several years ago. They also mentioned that there had been two known explosions of these units, both in helicopters in Canada. Even so, many of these are still available through multiple vendors to include Spruce. Despite my unit being past their warranty period they were nice enough to give me a discount on a new A344 unit. Much sturdier, you can have this unit serviced and refilled, gauge makes it easy to check and the bracket fits the same screw holes as the A400. The unit is slightly larger but still fits the same spot in my -8. The only down side in my case is that the top now covers a power port I’ve got. Got plenty of room to relocate it, just have not yet. The A344 unit comes painted in red or they have a chromed out bottle too for a bit more $$.
Here too:
Agreed, stay away from the A400. In my case, I found the plastic cap/actuator would pop off while the unit was nested in the cradle. Just what you want in an emergency. A can of Halon with no actuator on top. Get a full metal jacket
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 850 hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'... Eyeballin' vinyl really hard.
Yeah. The boss got a Silhouette Cameo 4 Xmas 2019.
Old 09-11-2019, 11:52 AM
snopercod's Avatar
Originally Posted by clam View Post
... any recommendations for extinguishers plumbed into the FWF?
I installed a 3/8" soft aluminum "spray bar" about 6" in front of the firewall at the top. It's above the gascolator, boost pump, mechanical fuel pump, and oil cooler. I plumbed it back to a fitting on the far right of the instrument panel that will accept my halon fire extinguisher. I also installed a temp probe (meat thermometer) in there so I would know I had a fire. I hope I never have to use it.
(2020 dues paid)
Old 09-11-2019, 12:06 PM
scsmith scsmith is offline
Default maintenance
I have an H3R A344 that has been in the cockpit for 10 years. Gauge still shows full charge.
Do I really need to get it "maintained"? What would change that would benefit from maintenance when the gauge still shows full charge?
Can maintenance of H3R halon fire extinguishers be performed by local fire extinguisher servicing companies?
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 09-11-2019, 12:34 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
According to the local fire extinguisher servicing company guy that I spoke to at length...
In a word, no. He says as long as the gauge shows in the green (that is, no the thing isn't leaking), you're good to go.
2019 Dues paid!
