Old 02-25-2019, 07:35 AM
pjc's Avatar
pjc pjc is offline
Sometimes I have to replace my fuel cap opener after I use it to mix epoxy. Good excuse to have another popsicle here in the Florida heat ...
Peter
Vans RV6 flying
SZD 48-2 flying
2018, 19, 20 Dues paid
Old 02-25-2019, 07:44 AM
Flying Canuck Flying Canuck is offline
I usually use a stubby combination wrench like this one. The 3/8" wrench is one of my most used tools so it's always handy.
If I'm opening the tanks during preflight check, I might use my Philips head stubby screwdriver that I carry to open my oil access door. This works okay but the wrench is a natural lever and the bend at the end makes it perfect for quickly popping open the fuel cap.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Interactive map of all of my flights here
Old 09-28-2019, 07:34 PM
I use my VW fold a key on the keyfob, from my Electric VW e-Golf. It has a flat, fold out blade, kind of like a switch blade.
Old 09-28-2019, 07:45 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I use a stubby philips head screwdriver that I use to open the oil access door for preflights.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 09-28-2019, 10:21 PM
gasman gasman is offline
If you need anything more than your finger to flip up the tab on your fuel cap, then your cap nut is adjusted too tight and you will end up breaking the hinge pin.
Properly adjust and lube the O ring, and no tools needed to pry up the tab. The cone of the cap must be able to slide and drop as the O ring decreases in diameter so it can fit through the neck of the tank.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 09-30-2019, 09:04 PM
Your finger nails are tougher than mine, Warren!😁
Old 10-01-2019, 06:38 AM
BillL BillL is online now
Good description of the function . . .
The force needed is very low and consistent with the right lube and adjustment. Although a fingernail works for me, the tool is easier and need not be very strong.
I have used Krytox for nearly a year now. My caps still open and close with a light touch and smooth as butter. No need to wiggle for the opening.
Bill
Painted 6.11.2020
No Photo on my post? => PM me.
Old 10-02-2019, 04:56 AM
dwmillsap dwmillsap is offline
My truck key has always done the job.
Dennis W. Millsap
Retired Air Force
RV-6A built, flown and sold
RV-10 built, flown and sold
RV-12 built and currently flying
EAA Technical Counselor and Flight Advisor
A&P
Old 10-02-2019, 05:26 AM
Flying again!'s Avatar
Flying again! Flying again! is offline
Nylon bicycle tire ?iron? work for me, already had a couple of sets so I use one for the RV. Here is a link on Amazon. $7 for 12, share with your friends, lol. Because it is nylon it does not scratch the painted cap.
https://www.amazon.com/Pieces-Bicycl...a-816053239080
RV-10 N331JH 3rd owner (First flew in 2005, #15 flying)
Northwest Regional 52F
Old 10-02-2019, 09:25 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
According to the number of posts I think that quite a number of pilots use a tool to open the fuel cap. So do I. I figured that it is quite difficult to adjust the nut in a way that it allows for opening by finger nail and still have the cap. fully secured in the filler neck when the lid is down.
On my plane it is an either or question. If somebody has a good way how to adjust I d'be happy to read from.
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
