Old 02-07-2019, 01:59 PM
lr172 lr172 is offline
Originally Posted by Nova RV View Post
Scott, I'm not questioning your analysis but how are lower CHTs bad unless they are so low the cylinders can't "expand" properly and not allow it to break in properly or cause increased wear? Lower temps within reason was always told to me as being a good or better thing.
My cut outs are similar to Keith's although slightly larger.
Thanks!
Yes, you can run too cool. However, I have no idea what is too cool on a lyc. There is a reason your water cooled engine has a thermostat. If your logic applied, a thermostat would not be necessary, just let it get as cool as it can. Automotive thermostats were put in place decades ago to keep temps up, not down.
Power is a function of heat. If the head is allowed to get too cool, you will unnecessarily lose combustion energy into the head instead of pushing the piston down. Engines are typically designed for an optimum level of heat loss through the head and ultimately optimum running head temps. There are other negative effects from running too cool, as well. CHTs are an indication of the balance between combustion temps, including combustion frequency and heat transfer from the head.
Ring seating has nothing to do with CHTs, nor does cylinder expansion. They are tied to cylinder wall temperature. The heads are aluminum and the cyl walls are steel. Very different heat diffusion rates. The cylinders also have different cooling fin design. I would not necessarily expect the barrel temps to follow a linear correlation with the heads and doubt that they do. However, I admittedly have no idea what the relationship looks like.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 02-07-2019, 03:32 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
From memory......Lycoming publish a number well below 200dF and TCM 225dF.
Interesting that TCM with their water cooled engine (a jacketed version of their normal engines) set the temp at 239.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Last edited by RV10inOz : 02-27-2019 at 02:52 PM. Reason: I retyped 225, when it was 239. Oops
Old 02-07-2019, 04:07 PM
Nova RV Nova RV is offline
Interesting that TCM with their water cooled engine (a jacketed version of their normal engines) set the temp at 225.
I found this in the IO 390 operation and installation manual, P.18
For maximum service life of the engine maintain cylinder head temperatures
between 150°F. and 435°F. during continuous operation.
Thanks for the reminder to go back to the manual for guidance !
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 06-01-2020, 05:36 AM
Wanted to post a conclusion here since I started this discussion. Bottom line is don't buy unknown brand thermocouple wire that claims to have the same accuracy as Omega or other quality types typically sold by good avionics shops. Once I replaced all of the thermocouple wiring the values changed considerably.
The wire became the focus once I did some more testing and found that boiling water would show as 192 degrees max on the cylinder with the most error (#2). I bought some replacement wire from Stein Air and rewired that sensor and found it to now read within a degree or 2 so all of the CHT and EGT wires were replaced and all are reading higher but in line with everyone else who have posted numbers for their -14.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
