Flaps zero vs reflex
bob888
Does anyone have data on performance differences between flaps zero and -3 degrees...esp takeoff performance? I can't subjectively appreciate any difference and it would be simpler to use just 3 flap settings...-3 deg, 15 deg, 30 deg and forget about 0 deg.
I get airborne earlier with flaps 0°.
Also, noticed even at low DA I lose 1-2 kts when I go flaps -3°
I need more testing.
I get a slightly shorter ground roll at flaps zero (in trail). And, at sufficiently high density altitude, slightly faster cruise at flaps zero. I wouldn’t remove the option.
flaps 0
With 150 hrs in my RV10, I still don't understand the flaps.
1-2 kts faster with flaps 0
shorter ground roll flaps 0
What good is the -3 position?????
Hey Dewey, maybe we should check your flap angles and see what they actually are; could the rigging be off?
It is interesting to read that there is some variation in builder experience with the cruise performance at different flap settings.
The RV-10 airfoil was designed to achieve a modest amount of laminar flow, and part of the expected benefit of the -3 flap setting at high IAS is that it increases the angle of attack a little to keep the airfoil well positioned in its modest laminar drag bucket.
If you have paint stripes along your leading edge, or less-smooth-than-average rivets on the wing forward of the spar - especially on the spanwise skin stiffeners, or anything else that might cause early transition, like just not washing the bugs off, then you may have early boundary layer transition and are not getting as much laminar flow - so you would not see the benefit of the reflexed flap setting (-3).
At very high altitudes, the IAS is low enough that zero flap is probably better. Also when flying very heavy, the altitude where the performance crosses over will be lower.
Thanks...
Thanks, Steve, for the clear explanation of the ‘reflex’ system. I’ve had my -10 for ten years and never run at zero degrees. Heavily loaded, on the way to the Bahamas, 4 aboard, baggage and full fuel, we still got 190 MPH, Plus, at 7500”.
Regards,
confused
Sorry. I did not mean to cause some confusion. I said this:
"With 150 hrs in my RV10, I still don't understand the flaps.
What good is the -3 position?????"
based on this:
BobTurner "... slightly faster cruise at flaps zero."
rdrcrmatt "... I get airborne earlier with flaps 0°. Also, noticed even at low DA I lose 1-2 kts when I go flaps -3°"
I have not done any flt testing to to verify any of this. While my plane is very well built, the POH is somewhat lacking in performance data. It is on my lilst.
It took me awhile to get to it but I go faster in reflex at all weights at and below 12k’. I cruise climb in reflex as well.
Takeoffs on my home grass strip is with 15 degrees - it gets me off with a shorter ground role. Takeoffs on longer hard surfaces are at 0degs.
I descend in reflex, I maneuver around the airport or on instrument approaches at 0 degrees. Zero degrees is kept until DA when I drop to full flaps (not the stabilized type approach the heavy stuff does but I’ve found it to be no problem to apply flaps and slow before landing. I always land with full flaps independent of the wind because I find the ‘10 to be very responsive in gusty high cross wind conditions.
Dewey,
Since you are quoting me, what I said was slightly faster cruise with flaps zero AT HIGH ENOUGH ALTITUDE, e.g., ABOVE 16,000’ density altitude. See Steve Smith’s post.
I do exactly the same, with the possible exception of approaches into 1/2 mile vis at night. Then I slow down, add more flaps, and copy the heavy guys.
