Old 03-20-2020, 05:52 PM
Amazon-1 Amazon-1 is offline
Default RV14A Canopy closed microswitch question
A couple weeks ago i recall a post about wiring for the canopy microswitch. The builder said he had to remove 13 rivets to install the wire. I am very bearly at that stage and i definitely don?t want to remove that many rivets for a simple wire pull.
I looked at the plans and pulling the wire to the switch is not mentioned as far as i could find. Have you run into this issue? Trying to avoid needless work here.
Thanks for any guidance.
Bruce
Old 03-20-2020, 06:35 PM
mturnerb mturnerb is offline
Most of us were able to work a wire through there without a problem. I fished a length of safety wire and used it to pull the wires for the switch. If you haven't fully assembled the canopy you may be able to put a pull wire in the channel before riveting the parts together.
The wire is installed in Section 61 - Canopy Harness.
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 03-20-2020, 07:14 PM
Allan Stern Allan Stern is offline
Default Micr switch wire
I used sika flex to glue both the canopy and side skins on and filled the gap under the canopy edge so I could not pull any wires. I think you can lay up two wires under those side skins before you rivet them.
I ran my two wires on the inside edge of the canopy railing gluing it down after using pieces if shrink tubing to hold wires together. May not be as asthetic as wire pull but works.
N507PW
140507 almost ready for first flight
Old 03-20-2020, 07:29 PM
Bavafa Bavafa is online now
Pull the wires before riveting the skin on the sides, it makes the job a lot easier. Although you only need one, I ran two wires prior to riveting.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 03-20-2020, 09:17 PM
JDA_BTR JDA_BTR is offline
I spent a good bit of time swearing on this one, fishing the wire through. The instructions really should offer the opportunity to run the wire before the rivets are set. I didn't think about it early enough. It is possible to get 22Ga wire pair down that run after the rivets are set - if no sealant!
I had some very stiff, small steel wire for a fish, and once I had one wire I used it to pull through the second.
I wonder if you could get a needle to pass some fine fishing line through with a magnet - thought about that afterward.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 03-21-2020, 05:06 AM
MED MED is online now
I put safety wire in place before riveting and used it to pull the electrical wire through after riveting, per the plans, I believe. I did not want to risk damaging the electric wire during riveting. It pulled through after without a problem.
MED
140236
N435MD
Miss March 2020
Old 03-21-2020, 09:02 AM
kbalch's Avatar
kbalch kbalch is offline
I was able to run the safety wire through, but was completely unable to fish the two electrical wires more than halfway. I wound up drilling out most (about 48) of the canopy side skin rivets to place the wires, then re-riveting the skin. Fortunately, I managed to do so without enlarging any of the holes or otherwise making a hash of it and the skin looks perfect now.
If I were to do it again, I'd place the wires prior to riveting the canopy side skin in the first place.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Old 03-21-2020, 05:03 PM
Don E Don E is offline
Default Took about ten minutes...
...to fish a piece of safety wire through and use it to pull the harness wires thru. Spent way more time thinking it was going to be hard than just doing it.
RV-14 Built
Can?t believe I built an airplane!
First flight October 22, 2018
N1477M
Kit #140329
If I had a nickel for every time I didn?t know what was going on, I?d be, like, ?Why am I always getting all these nickels??
Ka-CHING
Old 03-21-2020, 05:55 PM
jamesyoung2020 jamesyoung2020 is offline
Default Optional Canopy Harness Kit
Vans has a Canopy Harness Kit. May be a good time to order and install while you are working on the Canopy.
RV-14A
S/N 140408
