Old 06-24-2019, 11:45 PM
az_gila's Avatar
az_gila az_gila is online now
Question Flox tool question
Guys, what tools are you using to apply flox?
I have used popsicle sticks (large and small) and flex putty knives but can't seen to find a tool to apply small amounts neatly into corners.
What are you using?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2019, 11:59 PM
Yellow plastic bondo spreaders from auto body shop.
You can cut/shape as needed.
Old 06-25-2019, 04:05 AM
Default Spreaders
Harbor freight has the yellow plastic spreaders...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 06-25-2019, 05:10 AM
Auburntsts's Avatar
I've used a gloved finger more times than I can count.
Todd "I drink and know things" Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-25-2019, 05:13 AM
snopercod's Avatar
In a corner, the rounded tip of a Sharpie marker worked well for me. I also have a 4" length of 3/8" o.d. Teflon pipe that's handy on straight corners. The technique I used was to mask off the area on either side of the bead, apply the flox, then remove the masking tape with the excess flox. One final pass with the tool feathered out the edges. Sometimes I would use peel-ply over the joint.
(2020 dues paid)
Old 06-25-2019, 08:29 AM
I trim popsicle sticks to the shape I want. Any shape, as long as it's small. Metal cutters and a file for clean up, with scissors also working.
Old 06-25-2019, 08:50 AM
tomkk's Avatar
tomkk tomkk is offline
Yeah, I do the same with tongue depressors. Can trim to most any shape ...
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 06-25-2019, 08:59 AM
thinkn9a thinkn9a is offline
Default Caulk tool?
I haven?t worked flox,... but have used the caulk tools. Suspect they would work on small corners. The yellow spreaders mentioned earlier would be needed for larger areas.
Quick online search should get some good pics.
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 06-25-2019, 09:26 AM
Lynnb's Avatar
Lynnb Lynnb is offline
I've also taken to using some cheap silicon kitchen spatulas, both Mini and regular sized. I like that they are super flexible and easy to clean and reuse.
Lynn
RV-10 in Process
Old 06-25-2019, 11:17 AM
Is your mix too thick to apply with a 'horse syringe' ? That would get it into the corner, and then you could dress it with fillet tool of choice.
