GNX 375 intermittent GPS signal loss
jbDC9
Just checking to see if anyone else has run into this issue...
I have a new install GNX375 in my RV-8 that seems to have a glitchy GPS receiver, or something... it will intermittently and randomly lose the GPS position signal for a bit, usually between 5-15 seconds, then it reacquires the signal. The antenna is mounted on the rear turtledeck with new RG400 cable running under the left side floorboards and through the gear tower to the panel. The TNC connectors check out ok, no shorts that I can see. I swapped in a good known replacement antenna to see if that were the issue, but the problem persists, so it's not the antenna.
From the Install Manual:
6.4.1 Antenna Location
The GPS antenna should:
1. Be installed as near to level as possible with respect to the normal cruise flight attitude of the aircraft.
2. Be installed in a location to minimize the effects of airframe shadowing during typical maneuvers.
3. Be installed a minimum of two feet from any VHF COM antenna or any other antenna which may emit harmonic interference at the L1 frequency of 1575.42 MHz.
4. Be installed a minimum of two feet from any antennas emitting more than 25 watts.
5. Be installed a minimum of nine inches (center to center) from other antennas, including passive antennas such as another GPS or XM antenna.
6. Be installed a minimum of three inches from the windscreen.
7. Have a twelve inch center to center spacing between GPS antennas.
All of these requirements are met. The transponder and ADSB side of the 375 are working fine, no issues there. Is there a data log that I can download and maybe send to the Garmin guys to see if they can find the cause?
I really want to like this unit, but this GPS unreliabilty, plus the Bluetooth doesn't connect to my Samsung/Garmin Pilot tablet, plus the MapMX flight plan transfer to/from the Aera 660 is buggy... it's frustrating.
Has anyone else run into this?
Set the receiver to the ?satellite? page and have someone watch it, on the ground but in the open so it sees the satellites. Go around and push and pull, gently, on the coax and connectors (especially where the coax goes into a connector). See if that isolates the problem. I know when I assembled a TNC I didn?t push hard enough to snap and lock the center pin. The cable tested good, but wouldn?t make good contact when inserted into the female connector.
I have a KX165 when keyed on several frequencies would cause my 375 to loose the GPS. Notch filter fortunately cured that. Could an older comm radio be the problem?
Now that?s a good idea, hadn?t thought of that trick. Duh. Will give it a shot.
Interesting... I do have an old KX-125 in the panel, but transmitting on it has no effect.
An update;
My problem appears to be solved! Not that I’m all that smart of a detective... but, it’s my Spot tracker causing interference with my GPS reception. I read on another forum last week that the Spot tracker’s GPS burst signals would interfere with the Garmin GPS receiver, so over the last few days I tested the theory and flew a bit with the Spot turned off. The GNX 375 was rock solid, no signal loss. Apparently this is a “known issue” when the Spot and GPS antennas are fairly close together; sure wish I’d heard about this sooner! Ah well, it’s all better and I love an easy fix...
