Garmin G5 Software 6.60 Now Available
Seems a likely spot to ask a G5 question; how do you set the HSI display to compass arc mode and not the full compass rose? I understand that the Exp versions can do the arc but certified versions can?t; I?m doing a new install, fiddled with it on the bench and even read the manual but can?t figure it out...
G5 Software
This is only for the Certified version.
Wonder if the Experimental version is also due for an upgrade in software.
GOod Morning,
This was a maintenance update required for certification purposes in the GFC 500 STC program. We do not recommend loading this software into an experimental installation until we release it to the EAB Software Download area.
Justin
