skycloudster
I'm New Here
My RV-7 sat out in the rain and now I can't start it. I'm convinced allot of rain water flowed down thru the air filter. When I tried to start my IO360, I must have sucked that water into the cylinders. Isn't there a hole to drain water in a case like this? If not, I'm being told to drill a hole. Has this ever happened to anyone, if so, what did you do to clear things out and start the Mo Mo! Thanks, Sky
