Smothing the sign
cdeerinck
Does anyone have ideas on the best way to smooth the jaggies left by the stepper motors that cut the front of the Vans sign?
I have been using a Scotch-Brite pad, but it is going very slowly. A small flat-file was mostly useless.
Are most of you just doing with it as is?
I don't have a sign, but you might try a Dremel with a suitable tool. If one of their sanding drums will fit, it ought to work.
I used a small file on my airplane parts but on the sign, it is hanging above a window and you can't see the bumps from the ground.
I left it as-is, I kinda like seeing the manufacturing artifacts. I also put the screws on the front of the sign as I think it looks more industrial.
I used small files. (flat, 1/2 round, and round) Yes it took more time that the rest of the sign kit did. Do a little, move on to something else, then back to the lettering.
Mine is not perfect but the big jagged pieces are no longer there.
I did the same with AN470AD4 rivets on the front for the same reason.
