Foam for fiberglass and black RTV molds
Larry DeCamp
Just FWIW, I discovered a yellow foam at my local MENARDS that is a very fine cell structure like Elastafoam. It glues well to laminate, and sands very well. Not as coarse as normal Pink and Blue from big box outlets. A real plus is it comes in 2'x2'x 1" sheets instead 4'x8".
Just made some foam cores last week. My new go to is slabs of pink foam board from Home Depot glued together with Bob Smith Industries foam safe craft glue stk #962 126. It takes 10 hrs to fully cure, but holds well and sands cleanly. If needed fast dry drywall mud makes a good filler for minor fix up.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
What department is it stocked in? I wouldn't mind picking some up at my local Menard's (my favorite store) for a couple projects on the -9A.
David
It was with other foam near the contractor desk at my store. The pink was outside but the little 2'x2' was inside.
Chuck
Everything looks right. Mine is yellow, the web pic is green, so I cant assure you. The cell texture is very fine, it cuts and machines well and sands very well.
Thanks Larry. I will pick some up next time I am there. They have 96 sheets in stock at my store!
