Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 01-16-2020, 06:02 PM
You can use regular bent tube hose ends without the swivel stems. The only thing in there is an O'Ring. Usually a lock wire retains the pieces together---sometimes a crimped section. But the stem swivels (rotates) on the stem and they will leak. Some more than others. And the more movement, the more the o'ring stresses, and/or is exposed to the fluids---i guess fuel in this case--and deterioration starts.
Tom
Ridgeland, SC
Old 01-21-2020, 06:05 AM
rvflyerUk rvflyerUk is offline
Default Rv7
Note to Tom @ ts flightlines,
Yes, It's an Rv7.
