Old 12-11-2019, 03:59 PM
mmcelrea mmcelrea is offline
Default fluctuating rpm / map
Hi.I have a new titan io370 with dual pmags, c/s prop and afp150 vertical induction fuel injection system. It runs fine apart from at 1150rpm when the rpm fluctuates between 1100-1200. Also when running at 2300rpm the map fluctuates by about 1". All other rpm settings seem stable in rpm and map. I'm guessing that at 2300 the governor is maintaining the rpm. Not sure if its a weird resonance or something else is going on. The engine is brand new and has around 4 hours flight time on the aircraft. Has anyone else experienced this issue and how did you solve it?
Old 12-12-2019, 06:05 AM
mahlon_r mahlon_r is offline
The governor will not maintain 2300 rpm un less you set it to 2300rpm. If it is set for take off RPM then it will not kick in until you reach that RPM. So it is unlikely that the rpm is being maintained by the governor at 2300rpm.
What type of indications are u seeing? Electronically generated or steam gauges generated? can you hear the rpm change at 1150 or do you just see it on the tach?
Merry Christmas,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 12-12-2019, 06:21 AM
Plummit's Avatar
Plummit Plummit is offline
Does the EGT rise when the MP wanders at idle? According to Vic, (great webinar Vic!) you may have an intake leak. Just a thought.
-Marc
N814RV
2020 Donation Made
Old 12-12-2019, 06:43 AM
N941WR's Avatar
N941WR N941WR is offline
Do you have restrictors in your manifold pressure lines?
If not, the P-mag timing could be bouncing around, causing the fluctuations.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-12-2019, 08:33 AM
There is a restrictor in the manifold pressure line, I believe as supplied by Vans so i dont know if its small enough. It only fluctuates at 11-1200rpm and you can hear it change. From the garmin pilot app I can see that as the rpm decreases the map increases.
During flight when we set the rpm to 2300 its stable but the map fluctuates.
I haven't noticed the egt following any pattern.
The instrumentation is all garmin g3x.
Is it possible that there is something resonating at those frequencies?
Miller
Old 12-12-2019, 08:56 AM
Raymo's Avatar
Raymo Raymo is offline
Miller,
Download the engine data and upload it to Savvy Analysis for review. Allow the data to be shared and post a link here.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines (aka Hoser)
