Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-06-2019, 05:20 AM
rocketbob's Avatar
rocketbob rocketbob is offline
200nm trip @ 155 kts would take 77.4 minutes.
200nm trip @ 160 kts would take 75.0 minutes.
Ask yourself if that 2.4 minute difference on a 200nm trip is worth a couple AMU's.
Please don't PM me! Email only!
Bob Japundza CFI A&PIA
N9187P PA-24-260B Comanche, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 11-06-2019, 06:54 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Yep,
That?s the basic math I?m having trouble ignoring.
OK, thanks y?all.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F NW Regional/Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 11-06-2019, 08:09 AM
sf3543 sf3543 is offline
I have built two RV8s exactly the same except for avionics and prop.
Both had ECI 180 HP engines with fuel injection.
The first one had the 74" BA prop and the second had the 72" BA prop.
I originally got the 74" prop, even though VAN's recommended the 72" for tail draggers, since I felt there was plenty of clearance and in the event I had some tip damage there would be plenty for trimming/repair. The second one got the 72" prop because one became available from a new builder who decided to sell out.
Anyway, although I don't have any actual test numbers, I can say I couldn't tell the difference between the two.
Word on the street is that the longer blade climbs a little better and the shorter blade cruises a little bit faster, but I can't substantiate that.
At any rate, the BA props are definitely faster than the older straight blades. A friend of mine changed from the old straight blade to a BA and gained about 5MPH, as a previous poster also stated.
Good luck.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 11-06-2019, 05:36 PM
RV8JD's Avatar
RV8JD RV8JD is offline
That's not totally correct. Van's recommends both the 72" and 74" diameter props for the RV-8. But they only recommend the 72" prop for the other tailwheel models since they sit closer to the ground and have less ground clearance.
Ref: https://shop.vansaircraft.com/cgi-bi...sprop-hartzell
"The 74" blade diameter propellers are applicable to the "A" or tricycle gear aircraft except for the RV-8, while the 72" blade diameters are recommended for the tailwheel aircraft to ensure adaquate ground clearance."
This is a clip from their older order form showing that the 74" prop was offered for the RV-8, but not for the other taildwheel models:
The current Hartzell order form on Van's new website is actually incorrect as far as model applicability is concerned, as it does not differentiate between "A" models and non-"A" models.
Carl N.
Arlington, WA (KAWO)
RV-8, 750 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 11-06-2019, 06:15 PM
scrollF4's Avatar
...but the guidelines haven?t changed. Talking to the Mothership tech support verified that the 74? is still recommended and sold for the 7A as you posted:
Scroll
Exemption waived.
Old 11-06-2019, 06:53 PM
RV8JD's Avatar
Originally Posted by scrollF4 View Post
...but the guidelines haven’t changed. Talking to the Mothership tech support verified that the 74” is still recommended and sold for the 7A as you posted:
I was responding to Steve's post where he indicated that the 74" prop was not recommended for the RV-8, and I wanted to correct that so other RV-8 folks would know that the 74" prop is indeed suitable for the -8 per Van's.
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 11-06-2019, 08:10 PM
scrollF4's Avatar
Got it, sorry.
Scroll
Exemption waived.
Old 11-06-2019, 08:22 PM
RV8JD's Avatar
Got it, sorry.
No problemo!
Good luck on the prop decision!
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 11-29-2019, 04:23 PM
scrollF4's Avatar
Default Follow-up Question
OK,
Will the spinner, front plate, and backplate from my existing older 72" Hartzell paddle blade prop work on a new 74" Hartzell blended airfoil prop?
I'm terribly unlucky trying to catch the Van's tech support folks during their all-sacred tech support hours.
Scroll
Exemption waived.
Old 11-29-2019, 05:41 PM
Yes, but with a caveat.
I just did this exact change for a guy a couple of months ago. Everything worked out except that the front bulkhead nut plates didn?t align with the spinner holes, using the tapped holes on the new prop hub to mount the front bulkhead.
I was able to mark the holes through the spinner and move the nutplates on the front bulkhead for a perfect fit.
No other modifications were required.
In my case, the holes were off enough that I could just drill for new nut plates on the front bulkhead.
Good luck.
Steve Formhals
RV3B
RV8
