Old 07-06-2019, 11:44 PM
Driftdown Driftdown is offline
Originally Posted by psalys View Post
I just finished my RV-12iS and flew it a week ago. It took me two years. There is so much to learn in building an airplane. Here are a few things off the top of my head.
That was a great post, Patrick. Thank you.
Enjoy your new airplane!
Old 07-07-2019, 08:27 AM
It really is. It ought to be posted in the general section or the tips section.
Dave
Old 07-13-2019, 08:05 AM
shimuneka shimuneka is offline
Default Tables finished.
Well, I decided to go ahead and get the materials to build 2 tables. When i got home, I got a wild hair to cut the boards to length. That turned into my wife volunteering to help. 2 hours later, we have 2 tables completed. They are square, level, and sturdy. Very glad to have gone ahead and put them on wheels.
Old 07-13-2019, 03:53 PM
subpar_bucker subpar_bucker is offline
I am a first time builder who is about 75% of the way through my 12iS.
I agree with everything Patrick says. I will reiterate his line about the steel flapperon counterbalance tubes. There are jigs for holding a drill bit in place when drilling into curved surfaces. I would recommend using one of those (the problem is the steel is so strong and the skin is so thin it's easy for the bit to walk).
A few other points to consider:
If you can afford to do so, a builders assist like the one from synergy air is very valuable. My wife and I took the class together and finished the empanage in less than a week. http://synergyair.com/builder-classes/empennage/
Spend the $10 and add the electronic version of the plans *every* time you order the next kit. You'll get the most up to date version of all the sections. I have this on my home laptop and my work laptop. Conservatively I read each chapter 10 times before I start doing anything - and I *still* make mistakes You can put spare time at work/home to productive work by reading/rereading the plans before you put your hands on any parts. As many have noted prior, a less than 100% clear drawing on page 3 can be clarified by the drawing on page 10.
Cleavland is great beyond just selling tools. They have a great set of youtube videos on how to use their tools. Watch those videos. Also EAA Hints for Homebuilders - watch as many as you can stand
You can get deals on used tools here:
https://www.yardstore.com/
I bought my 90 degree drill from there and also managed to snag a #30 reamer that's about 1" long. My tech counselor was impressed I was able to snag that baby. Also: ebay.
Join local EAA chapter and get connected there if you haven't already. Most valuable decision I've made so far. I have a regular work partner who has already built a 12. His experience (AP/IA with 35+ years work experience) cannot be quantified. Paraphrasing my father: "his pinky knows more about building airplanes than I will ever know." Hopefully like me you'll get both a willing helper and a great new friendship.
The other valuable thing I did was read a builder's blog from start to finish. I found this one:
http://rv-12-n419aj.blogspot.com/
there may be others now devoted to the 12iS. These are a great supplement to the plans.
I actually built a 4x8 table on rollers. It has ~3.5 foot extensions hinged at each end. It's large enough with those extended to hold the wings while you are putting them together. I also built two EAA tables - they hold my stationary tools and sorted parts from the various kit paper bags.
One more piece of advice. From my tech counselor: "do it right the first time." It may seem trite, but I hear those words every time I screw something up If you aren't sure you can squeeze, or reach to pull a rivet stop and get some help. Pulling a 4-3 rivet correctly takes 1-2 seconds. Drilling out an improperly pulled or squeezed rivet takes considerably longer. The longer you build the better you'll get at knowing when you should stop. Error on the side of caution at the beginning.
Old 07-15-2019, 09:29 AM
Default Used rotax?
With this being my frist build, I really don?t intend to change anything about the airplane, except possibly set it up for basic IFR flight. That being said, if I end up doing that, I guess I am going to have to go the E-AB route. If I Am going to go E-AB instead of E-LSA I have been considering trying to find a slightly used or rebuilt Rotax to install, but I am having very little success finding much out there. I am nowhere near ready to buy one, but I am trying to figure out how much I might be able to save on a used or rebuilt engine vs buying a new one. Does anyone on here have any recommendations on reputable places to look?
Old 07-15-2019, 09:46 AM
Mich48041 Mich48041 is offline
You are allowed to make changes to an E-LSA after completing the 5 hour test phase, as long as the plane still meets the definition of LSA. So you may add IFR avionics to your E-LSA if desired.
Joe Gores
RV-12 Flying
Old 07-19-2019, 07:51 PM
Default Kit ordered
Well, I finally got around to ordering the kit. I want to thank you all in advance for the help and expertise I know you will all be providing.
Old 07-19-2019, 10:07 PM
jcarne's Avatar
jcarne jcarne is offline
Well heck ya, let the fun begin!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 07-21-2019, 06:57 PM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Default IMC
Actually you can build the RV-12iST which is a IFR trainer that is a S-LSA. So the E-LSA from Vans will be available at anytime. Remember that if your certifying E-LSA you need to stay out of any IMC with your IFR equipped RV-12iST.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
Old 07-26-2019, 10:33 AM
brucehatch brucehatch is offline
Wink Took the big first step
I have been vetting the RV-12iS kit for over a year now.
I traveled to this years Airventure (first time for me) and spoke with a number of -12 builders/owners or someone who knows a builder/owner. The feedback is always positive.
On Wednesday I took the big step and ordered the empennage kit. I feel a bit relieved now that the decision is finally behind me.
As a first time builder I'm really looking forward to the building process. That's the most attractive part in all of this for me.
Bruce
Working empennage kit
EAA Chapter 753, Provo, Ut.
https://eaabuilderslog.org/?s=brucehatch
Dues paid thru 2020
