RV10 builders/pilots,
I am pondering the fuel flow test as outlined in AC90-89B, Section 11, Par 1-19.e(1). For those of you who may have performed these tests, what climb angle did you use and how did you obtain it. I did a test with weighing down the tail and the best that I could get was about 12 1/2 degrees when the tail tie down hit the hangar floor. I am thinking about raising the main gear off of the floor, but was not sure as to what height would work out the best. I did place a call to Van's to see if they had a "standard" of unuseable fuel for the RV10, but the reply that I received was that it was up to the builder to determine that. Thanks for any information to help me get by this step.
Ed Godfrey
Ed Godfrey
